Old 09-21-2010, 06:24 PM   #43
Halltech
Drives: 2010 Halltech Camaro SS, 2008 C6Z06
Originally Posted by caverman View Post
Thanks Ted for doing this!!
Glad to see that the Halltech is only 4hp less than the CAI and ADM race.
Wonder what the Halltech would do with the ADM scoop. Do you think I would need to have the car re-tuned with the race scoop added? I'm wondering if it would be enough to change the A/F ratio.
Actually the Halltech Yellow Jacket tied the CAI intake on peak HP but had the higher peak torque (9lbs-ft vs. 7.7lbs-ft). Interesting that the IAT temps were 1 degree cooler for our intake even comparing it to the CAI with the add on scoop.
I think looking at just the intakes, without scoops, or tuning, Halltech is the leader.
Our Carbon Fiber intake fell on its face. Ted indicated that it was at +18% LTFs which puts open loop at way over 13:1 and knock retard, pinging....you know the drill. We have always stipulated that the Carbon Fiber unit needed MAF recalibration due to the 102mm cross section MAF read area.
Our testing showed a 4 HP gain with the Carbon Fiber Bumble Bee over the plastic Yellow Jacket. This with MAF re-cal only, and no other tuning tweaks.
The problem with the CF unit is it's extreme price vs. plastic.
I too wonder what happened to the famed Vararam?
Jim Hall
Halltech is offline   Reply With Quote
Old 09-21-2010, 06:33 PM   #44
Supercharged SS
Drives: 2010 Camaro
Originally Posted by tarheel34 View Post
Do you have to take out the washer fluid bottle or cut anything to use the scoop?
I believe the washer bottle needs to come out. I think I read that in the email from Ted on Monday when he was doing mine. I didn't mind, its never been used in over a year.
Old 09-21-2010, 06:34 PM   #45
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
wow thats good work. Its interesting though. While the hp & tq numbers on the CAI intake with the adm scoop are higher, so are the IAT's then the CAI w/ no scoop. I thought lower IAT's translates to denser cooler air which means more power. I'm not disputing the work, I'm just confused. By just adding the scoop your getting a good gain in hp and tq but how?
Outlaw77 is offline   Reply With Quote
Old 09-21-2010, 06:43 PM   #46
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
What the initial air temperature is before each test could and did vary.
What matters, is how well each unit holds the temperature down.
More torque and hp are gained by the scoop drawing in even more air.
Old 09-21-2010, 06:44 PM   #47
ssmike
BL1ZZRD
ssmike's Avatar
Great job Ted, thanks! It would have been interesting to see what difference the scoop made when used with all the other intakes! Maybe a CAI part 3 test?! LOL!
Old 09-21-2010, 07:14 PM   #48
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
As said, ambient temps will vary during the day. What's important is the variation during the run. All the ones you pointed out has zero temp variance which means they weren't affected by underhood temps. That's the key point in posting them. It would have been nice to see what the ambient temp was at the beginning of each test but i'm sure the 3k rpm temps were probably close if not dead on them. If you just went by temps, the OEM system had the lowest overall temps. It was also the first test of the MORNING, which means cooler ambient air. That brings up a good point though. The initial run of 372/364 was done with almost 10 degree cooler air than the ADM, CAI, and Halltech. I would think that could easily account for an extra 3-5whp. Yet I digress.
The scoop itself just puts more air into the area around the filter, meaning the intake doesn't have to "suck" as hard to get it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-21-2010, 07:16 PM   #49
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
Originally Posted by axis View Post
I'll have to get royalties if the "frankenstien" name catches on.
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 09-21-2010, 07:18 PM   #50
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
Looks like im ognna be saving up for a CAI with an ADM race scoop
LosXC451 is offline   Reply With Quote
Old 09-21-2010, 07:21 PM   #51
ssmike
BL1ZZRD
ssmike's Avatar
Is there any way of using the scoop without eliminating the washer reservoir?
Old 09-21-2010, 07:44 PM   #52
caverman
caverman's Avatar
Drives: '69 SS Convertible
I don't think so. Looking at the pictures it looks like the scoop goes right where the washer bottle is. If you were to leave it or get it to fit some how it would basically fill up the scoop and thus be worthless.
You should probably post that question on ADM's thread and see what that say.
http://www.camaro5.com/forums/showthread.php?t=90068
Build Journal
Old 09-21-2010, 07:48 PM   #53
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Why the K&N Typhoon but no standard plastic tube K&N intake???
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 09-21-2010, 07:51 PM   #54
ADM PERFORMANCE
Drives: Anything I want
ADM PERFORMANCE is offline   Reply With Quote
Old 09-21-2010, 07:54 PM   #55
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Awesome results!
especially when you can compare results with $ Price of units!
Looks like the Cold Air Inductions for $399 + $75 ADM Scoop does just about the same or better then the ADM Unit for $600.
Both appeared to do very well in testing. I do know for fact ADM quality is top notch.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-21-2010, 07:55 PM   #56
ADM PERFORMANCE
Originally Posted by JANNETTYRACING View Post
Again I would like to Show my Appreciation to all the Companies who Sent us Kits to test, this Says Alot about a Company and they're Products.
I also would Like to Thank Nick P, and Nick D, for donating they're time to help me with this daunting task.
Mrniceguy633 Thank you for the use of your 2010 Camaro and making the trek up here from NY twice, we enjoyed your company.
This was a big one we tested 14 systems in 9 hours, all the kits had to be preassembled to save time so no install times are included.
I have updated the 2009 test and included it, so scroll down to SEE, JRE V8 CAI TEST 9/17/10 on the spread sheet, this way you have all the data on one sheet.
I have added a note on systems that I feel from experience will do better with a tune due to fuel trim numbers and WOT A/F ratios.
If I have made any Typos Please bring them to my attention and and I will recheck the data, correct it, and make a new link.
Needless to say I am tired took me 2 days in between daily Phone calls, emails, and questions from my guys.
We got a big Surprise when we combined ADMs Scoop with the CAI kit.
If you don't understand the data Please ask and I will explain it in Clear English, sorry I don't speak any other languages
Enjoy
Cold Air Inductions was used as a CONTROL from the 2009 test.
And by Popular Demand we added and ADM Scoop to the CAI and WOW!
https://spreadsheets.google.com/ccc?...ZNVI5aVE&hl=en
Ted.
Your welcome TED
Got car back from Jannetty Racing Dyno results inside GQ4Life Forced Induction - V8 26 06-13-2010 04:51 PM
Coolingmist welcomes Jannetty Racing !! coolingmist Forced Induction - V8 25 05-13-2010 06:36 PM
Cold Air Inductions Intake and Jannetty Racing Chief Bob Vendor and Seller review / feedback / experiences 5 04-23-2010 02:45 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
