#71 |
Iceman
Drives: 2011 Camaro 2LT SC/RS CGM Join Date: Jan 2011
Emailed IPF today about the new pulley and gave them our new address. No reply as of yet Keep you posted
#72 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
They have everybody that purchased the kit on the list, Brooke should send you an email shortly..
#73 | |
Iceman
Thx ![]()
#74 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
#75 | |
Iceman
#76 |
Let me know directly if you don't hear from them. I have ways.
John B. |
#77 | |
Iceman
#78 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
I want to thank IPF for taking care of its customers, that is very professional of them. If anyone has more issues with the bearings, I have found a high speed replacement bearing capable of over 32k rpm and will run cool. They are a ceramic hybrid bearing with a high temp composite bearing cage and fully sealed, they are not cheap. I bought some to test out on my pulleys. If you are not aware, I replaced the supplied pulleys with some custom pulleys made with a larger bearing installed and a slightly larger diameter to reduce the RPM. My latest set of bearings have lasted over 7500 miles and are still good. I am experimenting with the hybrid ceramic bearings now. We all want our systems to be the best , most reliable out there, so it advantageous to experiment to see what works and what does not.
#79 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Very nice! are these interchangable with our current bearings and fit in the IPF pulleys as well or just available in the larger sizes?
#80 |
COTW 5/06/2013
I can get sizes for the ipf pullys too
#81 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
You can get the silicon nitride ceramic bearings in 6003 size to fit the current IPF pulleys. Make sure you get abec 5 or 7 to insure tolerances for high speed and high temp. I have a set from work that are aerospace qual but have not put them in yet. I'm running the new bearings from IPF and monitoring.
These ceramic bearings are expensive $50 - $70 apiece but they should last.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
#82 |
Tonkaracing
U BEEN TI THE TRACK .WHAT NUMBERS YOU RUNNING
#83 | |
![]() ![]() ![]() Drives: 2014 custom blue ZL1 Join Date: Jun 2011
#84 |
Drives: Camaro, CTS-V, Escalade, GMC Sierra Join Date: Nov 2011
Hello All,
I have received a few PM's here and there regarding the bearings shipping addresses, some to Arno and some to myself, If you need assistance or have not received your parts PLEASE contact us through the proper business channels, not VIA PM. I have had sales and customer service issues fall through the cracks here. I want to make sure everyone gets the parts or information they require. Thanks for the kind words and support from our loyal customers! However we are very busy and do not check the forums everyday. If you have an important matter, phone or email is always the most efficient way to contact us. Myself: Andy@kpe-products.com Tech: Support@kpe-products.com Phone: 888.222.4291 LV MSG if no answer. FYI - This rings to my mobile during normal business hours using option 1 or 2. I return calls and emails usually by the hour. PM's may go unanswered for 24 hours or more. Thanks Again! |
