#113 | |
![]() Drives: 2010 CGM 2SS/RS 6M Join Date: Feb 2010
You interested in selling a harness like that?
#114 |
![]() Drives: 2010 2SS/RS - Rally Yellow Join Date: Dec 2008
Id be really interested in the harness as well .....I woud prefer a more easy plaug and play .... Also are there lights the will fit into a 2ss that match the RS headlights ???
#115 |
![]() Drives: 2010 SS/RS Join Date: Jun 2009
Very possible
I hadn't thought that far into it when I was designing it, but if there is an interest I just may consider it.
I'm not sure I know what you mean by 'match'....... the halos? There are vendors here on Camaro5 that can answer that question. I have the RS, that is what I made my harness to function with. Several configurations are possible, it depends on your needs. Fieldgoal00 and I have been working on a remote switch option for full control. |
#116 |
![]() Drives: 2010 2LT RS Camaro 2015 Colorado Join Date: Dec 2009
[QUOTE=FwyFlyer;1543714]I hadn't thought that far into it when I was designing it, but if there is an interest I just may consider it.
Interested
#117 |
[QUOTE=OKCwhiteKnight;1543771]Also Interested.
Delivered 25 Aug 2009: ![]() 2SS/RS LS3 |
#118 |
Drives: 2010 Chevy Camaro 2SS/RS Join Date: Dec 2008
check the bottom of this thread, FwyFlyer and I are almost near completion, if interested pm us, we'll start a new thread with results and a pre-order list.
http://www.camaro5.com/forums/showth...t=65535&page=2 |
#119 | |
ACCOUNT HOZED BY GN......
Hey Jeff, got your harness all wired up last night...works great!!!!! very easy to follow instructions and all of the connecions fit perfect. This looks like it came on the car from the factory...Great Job!!!!!! ![]() Ronnie |
#120 |
![]() Drives: 69 Z-28, 93 Pace Car Join Date: May 2010
just a quick question............do the drl's or fogs go off when the hi beams are turned on or are they on all the time with this mod..............in jersey they need to go off with the hi beams.
#121 | |
Camaro Crazy
Drives: 2010 1SS/RS IBM/Grey M6 Join Date: Jun 2010
I called over to chevy and priced the switch and along with that a pair of fog lamps and he told me there is a little harness you need for each side. Now I dont know if these harnesses plug into a plug behind there thats now hanging empty or if it plugs to the same place the drl's are plugged in. The other thing to consider is that someone mentioned having to reprogram the bcm to make the fogs work. I know in ford where I work we did this to a taurus x last week that came from a state where the drl's arent normally on and now that the car is in new york he wanted them on and we went in and turned them on. We need a gm tech to assist us with this. or if we could hear from the guy on the assembly line that can tell us the difference when they build them |
#122 |
nice mod
#123 |
CAPTIAN CAMARO
So with this mod the drl's work the same or do the halos turn on as well when in auto mode.
#124 |
![]() Drives: '10 Camaro 2SS/RS CGM LS3 A6 Join Date: May 2009
With this, everything will work normally, day and night, except now whenever the parking lights are on (auto or manual modes, hi beam or low beams) the fogs will be on too.
As an update: I've now had this mod for over 14 months, had it for over 15,000 miles, on my several long road trips, had my park lights and fogs on for hours and hours at a time, non stop, used it in all weather conditions from hot and humid to snow and ice, used it in all temperatures from 8 to 118 degrees F, used it in all elevations from -25 to 9,500 feet, and have had zero problems, with wiring, with LEDs, with computers, you name it, no problems. When done correctly, as described in my instructions, it is a perfectly safe (and extremely cheap, I might add) modification to make your lighting the way it should have been!
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
![]() Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc. |
#125 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
Although, I would prefer to just purchase the harness; This is just brilliant.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
#126 |
WILDRACER
hello guys ( and ladies).. i am new to the site and have been getting alot of great ideas thanks for that... but what i would like to know is ?? i have a 2010 2ss/rs and i have been reading this mod and would love to do this. but i have never seen my drl's on at all.. and i have been looking for the fog light switch with no luck???
| Fog lights | camarogolfguy | 5th Gen Camaro SS LS LT General Discussions | 36 | 12-03-2017 08:42 PM |
| How to convert DRL to hid fog lights on your RS Camaro | FI4T0MCAT | Cosmetics and Lighting Modification Discussions | 30 | 07-24-2013 03:31 PM |
| FOG LIGHTS ON RS | blueforza | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 04-17-2011 08:04 PM |
| Automatic Fog Lights | cmgolfr212 | 5th Gen Camaro SS LS LT General Discussions | 13 | 05-16-2010 03:48 AM |
| fog lights again | BigTrap1967 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 9 | 09-14-2009 10:09 AM |
