#743 |
![]() Drives: Camaro 2014 2LT Join Date: May 2014
How would you go about this, if I wanted to connect to the dimming switch (to the left of the steering wheel) to control the lights?
#744 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 2SS Join Date: Apr 2011
Answered your question in the other thread you posted about this.
#745 |
Dunder Mifflin Inc.
Drives: 2012 2SS/RS Convertible Join Date: Jan 2014
My only question is, where do the passenger footwell lights get power from? I don't see where you attached the red wires for the passenger side lights (you tapped into the grey wire for the driver side).
#746 |
![]() Drives: 2011 RED Camaro Join Date: Sep 2011
You run a wire over from the passenger side to the drivers side.. This is a really easy install.
#747 | |
Dunder Mifflin Inc.
I don't actually have the strips in front of me, so I'm not exactly sure what they look like. Are the light strips attached to eachother, so I'll have one red and one black wire in total? |
#748 |
Dunder Mifflin Inc.
If I buy T-Taps like the ones below, do I need to buy a male end for them? Or is this all I need? I'm new to this, so I don't know very much!
http://www.amazon.com/gp/aw/d/B001JT...dir_mdp_mobile If somebody could explain to me what the T-Tap process is, I'd greatly appreciate it. |
#749 |
![]() Drives: '11 SW 1LT RS Join Date: Aug 2012
Ya, you need a spade to slide into the end. You just wrap that thing around the wire, it clips or snaps on then you add the "tap" really really easy.
#750 |
Dunder Mifflin Inc.
I just purchased these tap splices. They're 22-18 gauge, so they are the same gauge as the dome light wire. These will work, right? I shouldn't need anything else to splice the two wires?
#751 |
Dunder Mifflin Inc.
Thanks a ton for the write up. Installed it today, only took about 20 minutes and it looks fantastic. I used a tap splice instead of the T-Taps because I could fit both of the LED powers into the one splice, rather than 2 T-Taps.
Footwell lighting definitely adds a luxurious feeling to the interior, I can't recommend this mod enough! |
#752 |
![]() Drives: 2014 Black on Black 1SS RS Join Date: May 2014
Does anyone know if he connected both positive wires to the 1, 3 Amp Fuse that he used or did he use 1 In Line Fuse for each Positive Wire?
I plan on using 2 LED Strips, 1 for each side. Also, about how much extra wire do you think you used to wire everything together? Thanks.
Jim.
A.K.A. 2K14Ro |
#753 |
Easiest to just use one fuse.
#754 |
HOLY F*** S***
Man,... I've had 4 Back Surgeries, 3 Back Fusions and 1 Neck Fusion and I just attempted this today in the Florida Heat in my Driveway. Being 6'2" I thought I was going To Die today Ladies and Gentlemen. Not to mention I F****** Up! All Day I kept telling myself Grey Wire 1st Socket, Grey Wire 1st Socket, Grey Wire 1st Socket and what the hell did I do? I was and Am, So Pissed,... It just started getting dark and I started rushing at the end. Hey, I have a question for everyone here Please.. Something Strange happened when I ran my wires Behind the Dash from the Passenger Side to the Driver Side. I used a Homemade Cardboard Stick about 18" Long to feed the Wires through. My Keys Were Out of the Ignition and when I Poked the Wires Out by the Drivers Side, Everything Dinged Once like I had turned the Key On and my Trunk Popped Open. Any Ideas? Also does anyone happen to know what the other grey wire that connects to the 2nd plug is used for by chance? I bought the same kind of Taps as CyberGreyConvertible did but mine are 18/20 (18 Being the Inside/20 the Outside-Just So You Know) because that's all that RadioShack carry's so I guess I'm going to just cut my Fuse Off and leave that Tap in place and try again with that Grey Wire in Plug #1. Anyone see any Issues with that? Thanks everyone. Jim
Jim.
A.K.A. 2K14Ro |
#755 |
The connector next to the grey one has two grey wires. They are for door lock unlock signals.
#756 | |
Thanks for the info friend. Jim
Jim.
A.K.A. 2K14Ro |
| Where to wire in ambient footwell lighting? | cybercoaster | Cosmetics and Lighting Modification Discussions | 32 | 01-11-2016 12:08 PM |
| Anyone have the Footwell Lighting Kit Installed? | wildthing001967 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 07-03-2011 06:00 PM |
| AACStyle footwell lighting problem | TRSS2 | Camaro DIY & HOW-TO instructions & discussions | 8 | 01-23-2010 07:41 PM |
| footwell neon lighting. How to wire to have it come on the other ambient lighting? | Jakefeb3 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 11-22-2009 10:32 PM |
