Old 01-01-2010, 07:37 PM   #29
TK-Bear
Cybertron
TK-Bear's Avatar
Drives: Silver Camaro with Orange Stripes
I just want to say thanks for this thread as I just installed mine today on my car and I love this feature. I will admit the hide away plate is somewhat pointless, but it is fun and cool. Once I get a chance I will post some pictures of what I did for mine. Thanks again, great info and fairly easy install!
Ordered My Camaro on November 18th. / Built on December 4rth / Arrived on December 10th / Stripes were finished and I took it home on December 15th 2009!!!
TK-Bear is offline   Reply With Quote
Old 01-31-2010, 10:49 PM   #30
Tom D
Tom D's Avatar
Drives: 10 Camaro SS/RS RJT
I would also like to connect to be automatic with start-up. Anyone have any ideas what to splice into so we don't have to use a remote or push a btton?
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
Tom D is offline   Reply With Quote
Old 02-13-2010, 10:20 PM   #31
jleinaweaver
jleinaweaver's Avatar
Drives: 2010 Camaro 2LT RS
Originally Posted by tradosaurus View Post
Unless you show your car I don't get the hide-away function.
If the front plate is required by law then just mount on front and be done with.
Actually with a personalized license plate I want to showcase it on the front.
To each their own.
I bought the manual one because I wanted something that mounted on the bottom, where the holes wouldn't be visible. I just can't bring myself to drill holes in the front bumper.
jleinaweaver is offline   Reply With Quote
Old 05-20-2010, 05:30 AM   #32
Camaro68
Camaro68's Avatar
Originally Posted by NYG71 View Post
Good write-up. I just installed mine this afternoon. Took 2 hours, very simple. Now I am legit.
How is it working out for you?
Do you have pic's of it installed?
Old 05-27-2010, 08:52 PM   #33
rdono
Cavallino
rdono's Avatar
Drives: 2010 SS/RS IMO-IMO
I have one I am not going to use as it will not work with GFX. never installed, new in box - send me a PM if you want it, I will make you a long deal.
rdono is offline   Reply With Quote
Old 07-05-2010, 11:41 PM   #34
Camaro68
Camaro68's Avatar
please take a picture of it in hide away mode, looking down on bumper
Originally Posted by Xmicro_SS View Post
Well, I waited a few weeks for this product because I was told it was so busy that they were on Back Order. It was $150.00 shipped. From Here: http://www.swiftmotorsports.com/prod...9f31e771cba318
Here is the Video of my car, Note:The Plate frame is bouncing when lowering due to extra weight of Chrome Plate frame I installed:
This project only took about 2 hours, but that is because of placement decisions and some Camaro Specific things that were not on the directions. So I thought I would post what I did and how it came out here, to help my fellow Camaro Brothers out. Here are the Steps I took. And you can see the descriptive pics I put below to support what I write here.
1 - Open Hood, Put double Sided Tape on Back of Module
2 - Place on left Sidewall, Under hood(See pics)
3 - Drop Control Wires down to the ground (double wire with clip on end) to inside of wheel well cover
4 - Jack car up at this point
5 - Place Masking tape under car where installing to mark area to drill
6 - Pull Plate holder slowly forward so it pops up
7 - Find Placement and mark three holes (as per instructions)
8 - Drill Holes (per Instructions)
9 - Run the wire through, from back to front, between the black plastic lip and painted fascia on the left side
10 - Properly Place wires on motor connectors (as per directions)
11 - Cap Wires and Motor, using supplied cover, and use ZipTie (Per directions)
12 - Remove the two Fascia Bolts under the front fascia (SS MODEL)
13 - Use the Black Screws and the Black Rectangular Flat Nuts to install...Not the stupid rubber sleeves they tell you to use!!
14 - Place your hand , while holding Flat Nut, through the dropped lower lip and hold over the very front drilled holes.
15 - screw through the frame holes into the flat nuts, your holding, to get good secure attachment.
15 - Adjust frame as needed (front to back so that the plate stands up straight and screw tight.
16 - Replace 2 Factory, under Fascia Screws back
17 - Tuck Wire under Black Lip hanging from fascia, nice and neat (See pics)
18 - Let's Wire it up. Lower Car and remove Jack.
19 - First the ground. Attach the black groud wire to the screw holding the plastic radiator surround in (See Pics). Remove the screw completely and put the ring connector under the plastic.
20 - Very Important to make sure the INSIDE OF THE RING TERMINAL MAKES CONTACT WITH THE SCREW as you put the screw back!!!! Or you will not get ground and therefore no power!!
21 - Open the Fuse box and attach the red lead to the main hot terminal by unscrewing slightly and slipping the terminal under it enough for it to bite. The terminal connector will NOT fit over the post so no reason to remove the nut on there completely! Close the fusebox.
22 - Use the supplied wire harness wrap to wrap up all the extra wire and use electrical tape to secure it to the factory harness. You can also use a zip tie to pull up the excess wire going down to the frame and zip tie it to the harness you just created.
23 - Run the little wire antennae between the two body panels that go toward the strut towers (see pic).
24 - Use the remote to test and see if the frame is working. If not, check the ground.....Make sure it is making contact with the screw. You may need to bare the screw slightly with some sandpaper if you are not getting proper ground.
25- Position the foam stopper on the back of the plate holder as per directions!
You are done! Enjoy and I hope this helped!
Do you have a picture of it, in hide away mode looking right
down on it so I can see how far it comes out?
Old 10-10-2010, 11:45 PM   #35
Ratcals
Ratcals's Avatar
Drives: Black,IOM stripe, 2SS
Look straight down from the SS badge and you can see how far it sticks out...not much if you mount as far back as possible.
Follow the directions from Xmicro_SS. He was spot on.
Ratcals is offline   Reply With Quote
Old 01-20-2011, 08:42 PM   #36
Camaro68
Camaro68's Avatar
Thanks it dose work great, when
I get a chance I will post a thread
with pictures of it.
Thanks again fellows
Old 04-07-2011, 08:13 PM   #37
svtjackal
svtjackal's Avatar
Drives: 2010 SIM camaro-2001 svt Lightning
Thanks man, I have been trying to get a good ground for my motorized plate for the last 4 hours and I could not find a good ground then came across your thread and tried the ground you used and works like a charm,
I have the GFX and I works and looks fine BTW.
Illinois, Indiana, Wisconsin Camaro Owners check out www.chicago5thgen.com
svtjackal is offline   Reply With Quote
Old 04-07-2011, 11:21 PM   #38
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Amazing how a thread is a gift that keeps on giving. Glad I could still be helping members over a year later.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 04-08-2011, 10:47 AM   #39
FIVE-O
Drives: 2011 Camaro 2SS
Originally Posted by markssylver View Post
can that be mounted in the middle?
You can always tell a states intelligence by whether or not they have two plates/tags or just one. Duhhhhhh....I wonder which would cost the state less money? IDIOT STATES!!!
FIVE-O is offline   Reply With Quote
Old 04-08-2011, 05:09 PM   #40
HumanWiki
Drives: Car
Government and Logic/Intelligence rarely go hand-in-hand unless you're a Corporation.
HumanWiki is offline   Reply With Quote
Old 04-22-2011, 09:42 PM   #41
Chiefs Fan
Chiefs Fan's Avatar
Drives: 11 Vert, 2SS/RS, M6, Victory Red
Great job
Chiefs Fan is offline   Reply With Quote
Old 04-23-2011, 12:19 PM   #42
Jayhawk500
Jayhawk500's Avatar
Drives: 2010 Camaro SS/RS
I tried installing this on my car. I wasn't impressed on how far the track stuck out the front.
If anyone would like to purchase this from me, PM me and I'll sell it cheaper than what I bought it for + shipping. It does have an extra hole in the track for mounting.
I zip tied the front plate holder on and can remove it for shows.
Jayhawk500
2010 2SS/RS, Six speed, Rally Yellow w/ Black Painted Stripes, Boston Acoustic Stereo, Polished 20" wheels, Solo Mach X Catback Exhaust, Solo HF Cats, Halltech CAI, Full Dash & Door ABL, ABL Lit Homelink Buttons, HUD Installed, Ride Tunes, Full Electric Passenger Seat, Fbodfather signed, VIN # 4492, PAID OFF!!!
2010 Yellow 2SS/RS with black painted Stripes...$37,000.00; Ride Tones sound system and remote...$ 40.00; Seeing the kids faces (Young and Old) light up and almost wet their pants....Priceless!!!
Jayhawk500 is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
CGM w/ black or chrome license plate frame, what do you think? Matt'sSS Camaro Photos | Spyshots | Video | Media Gallery 14 08-04-2009 04:11 PM
INDY 08 Attendees!!!!! TRIXXTERR Off-topic Discussions 19 12-01-2008 05:29 PM
