Old 09-13-2012, 07:31 PM   #169
Blue70SS
Blue70SS's Avatar
Originally Posted by IDEALG View Post
they don't make one yet, only i sell a modified master cylinder.
And it Works......
LPE Brotherhood
Old 09-13-2012, 07:36 PM   #170
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Originally Posted by Blue70SS View Post
Fast seamless shifts, very streetable after broken in with a good racing night. Couldn't be happier.
AWESOME!
Hendrix-Engineering is offline   Reply With Quote
Old 09-13-2012, 10:38 PM   #171
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Originally Posted by Hendrix-Engineering View Post
The Street Slayer has LESS clamp load than the stock clutch,it works GREAT with the stock slave....
Even my twin carbon has less clamp load? Thats Badass.. I got out of my 2010 with the "AHEM... MNSTER" and got in my new 2013 2SS and I giggled when i first drove it.. the clutch was effortless and my 2010 felt like it was pushing a golf ball through a garden hose.. CANNOT WAIT FOR MY TWIN CARBON!!! HINT HINT THOMAS.. hahaha
The 2010 Sin is offline   Reply With Quote
Old 09-16-2012, 12:21 PM   #172
maxdmax
maxdmax's Avatar
Drives: 2010 Camaro SS/RS
I had the issue of my clutch sticking to the floor during a hard runs speed shifting, so I put IDEALS master in my car on Thursday. I blead the clutch per his video and it does appear to have fixed this issue. So either the master did the trick or the bleading process did it. Either way I am a happy camper for sure!
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
maxdmax is offline   Reply With Quote
Old 09-16-2012, 01:33 PM   #173
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Good to hear!
IDEALG is offline   Reply With Quote
Old 11-24-2012, 06:10 AM   #174
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Has anyone found a real solution for this? I had this happen to me when I dumped the clutch to do a burnout at the track a couple days ago. The clutch peddle stuck to the floor and all I could smell was clutch and fluid. I must have burned it pretty damn bad.I looked like a complete idiot. Any chance with could be a warranty fix?
AdamZ is offline   Reply With Quote
Old 03-11-2014, 12:19 AM   #175
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Had to bring this thread back. I never had the problem with the pedal sticking down until about 74k miles. I've done quite a few power shifts at WOT with no problems. Now it wants to stick down if I try a hard shift under power and it does it when it is cold unlike most of the others that say it is a fluid heating issue.
I have the heads off to replace lifters and cam and won't be able to put things back together for a few more weeks. If it's possible I will bleed the line out while I'm doing the rest of the work and see if it cleans out good. It's never been a problem when it's hot. I think it's just got dust in the slave cylinder.
Any other fixes out there yet?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 03-11-2014, 12:38 AM   #176
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
A new clutch is a good solution. And you have good access to the top bolts on the bell housing with the heads off. The monster LT series is pretty good and feels stock! Worth a look if you have the opportunity.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 05-07-2014, 02:37 AM   #177
BES Stroked
Drives: 98 Camaro race car
I just wanted to add that we installed a pre 2010 corvette Tick Master into a 2012 corvette and seen no problems, the only problem we seen what that we couldn't fully control the release speed with our foot at first being used to the stock one it was tire spin hard at the track, once that was learned, it shifted great.....
NOW I have a 2011 camaro and fighting the same problems I had when I first got a Tick performance master in my 2000 camaro SS, and later on with Tick I went 8.80's with their T56....
anyways I would really think there is something here to be gained. I am on the edge trying the modified stock one from idealg.....
11 2SS/RS M6 IOM Polluter'd
98 Camaro LSX Real Street 8.14 at 169
08 Cobalt SS/TC 310whp
06 Duramax LBZ EGR! 4" straight, DSP5
BES Stroked is offline   Reply With Quote
Old 06-20-2016, 06:34 PM   #178
victoryred14
Drives: 2010 2ss
I have had my clutch pedal stick to the floor since day 1 with high rpm aggressive shifting (even in the quarter mile - tough way to go down the track). I've had a Spec Super Street twin disc and a ZR-1 clutch. Never changed the sticking problem. The Spec was better than stock, but not as good as the ZR-1.
I don't ride the clutch. I've changed the fluid several times. I will try DOT 4 after reading these posts.
victoryred14 is offline   Reply With Quote
Old 06-20-2016, 06:36 PM   #179
victoryred14
Drives: 2010 2ss
I've also had to replace the slave cylinder. Did not help the sticking.
Old 08-01-2018, 10:46 AM   #180
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
Bringing this thread back from the dead with some great news: after literally YEARS of research and development, the Tick Performance Billet Adjustable Clutch Master Cylinder Kit for 2010-15 Camaro SS & ZL1 & Z28 is FINALLY available: https://www.camaro5.com/forums/showthread.php?t=535330
This kit is custom CNC machined here in house at our facility in NC, USA and is the only truly aftermarket clutch master cylinder solution for these cars. It offers an increased cylinder bore which allows the hydraulic system to flow enough fluid to fully disengage ANY clutch and it is made adjustable so there is no chance of flowing too much fluid and risking damage to the slave cylinder and/or pressure plate.
This kit will allow you to drive your Gen 5 Camaro like it is SUPPOSED to be driven! Much more pictures and video coming soon. If you guys have any questions, feel free to ask!
Edit: YES, it fits the V6 cars, as well!
Matt@Tick is offline   Reply With Quote
Old 08-06-2018, 09:12 AM   #181
xc_SS/RS
pre order placed! looking forward to seeing how it works
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-06-2018, 09:43 AM   #182
Matt@Tick
Matt@Tick's Avatar
Thanks for your order, you won't be disappointed.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
