02-20-2013, 12:07 AM | #1891 | |
Drives: G5.R Join Date: Sep 2010
************************************************** ** I've been working on my second coil relocation setup, LOL. I'm working with Blue Streak (Known for NASCAR wires) on a custom set for G5R. They sent me a bunch of different ends to see which will work best. Once I have the sub put together, I will be able to drop the engine and go from there. These were kinda cool. They have a ceramic shell for heat dispensing purposes. I am thinking I'll go with these as the are the lightest. Last edited by Moreno1; 02-20-2013 at 12:24 AM. |
02-20-2013, 09:03 AM | #1892 | |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
02-20-2013, 10:38 PM | #1893 |
Drives: 1987 Corvette TPI Join Date: Mar 2012
02-21-2013, 09:43 AM | #1894 |
02-21-2013, 09:46 PM | #1895 |
Drives: 2011 2SS Convert; Color RJT Join Date: Sep 2009
Hey Nathan. Your project looks great. You posted somewhere you had a metal polisher that did great work for you. I have a old LS3 TB that I'm replacing with a Vmax that a local friend want to buy from me, but wants it polished. What is his rate for TB polishing? Thanks for any info.
02-21-2013, 11:39 PM | #1896 | ||
I guess I've lost my mojo Need to get my game back! Quote:
************************************************** **** Quick random update: Received a few more billet pieces today. This is my second rendition of the upper radiator hose. Since I'm tucking the radiator under the core support, I decided to use an inline filler. The black anodized billet cap is from Billet Specialties. This is just a mock up and not the end product. I will need to purchase two more of the straight couplers, 4 more clamps, etc. Here is a close up. I will be running a hard line that will loop around and under the hose to the over flow tank. This is also another mock up to give you guys an idea. I will be welding a -3 90 degree AN fitting on the tube which is where I will be connecting the water vapor line. Part of the racy, mechanical look I'm shooting for. Received my Ring Brother hood pins also. Spoke with Mike Ring today. He gave me some tips on the best way to finish off the carbon for a stain look. He mentioned that they are talking about doing a ZL1 for SEMA this year. If you know their work, you know thats going to be the most stunning ZL1 ever, PERIOD! Here is the Stang they did last year. There's over $10,000 in custom carbon pieces. Here I am soaking up the beautiful detail work! Recieved a few more of the ZL1 pieces I will be getting replicated in carbon. RJ, these are a few of your fuel line system. Let me know if you'd like me to polish the QD on the fuel line. Waiting on some more parts for you. Mike2SS, this is the piece you will need to weld onto the radiator tubing for the oil cooler. I can't remember the size. I think it's a -8. The place I got it from is near my school. I can drop by next week on my way to college and get you the size, part #, etc. I looked up the part # for the aluminum tube and its 917-1001-1.25 from Speedway. Sells for $16.99. |
02-23-2013, 12:20 AM | #1897 |
Sneak peek ........ replacing the hard line with braided steel lines.
02-23-2013, 02:51 PM | #1898 | |
Drives: 2012 45th Anniversary 2SS Join Date: Mar 2012
That is Beautiful man! What a work of art.
02-23-2013, 04:03 PM | #1899 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I completely agree. Everything that you have done/ had done is truly a work of art, really wish I had your skill. Keep it up
02-24-2013, 03:20 PM | #1900 |
Nathan,
Do you have a source for your rocker panels. Our dealerships want a nice amount of coin. ZooDad Sent from my HTC6435LVW using Tapatalk 2
2010 Camaro 2SS/RS - Summit White
K&N 63-3074 LSR Performance Tri-Ax Shifter Eibach Pro Kit - Springs |
02-24-2013, 03:59 PM | #1901 |
NJ/SoCal HT5 COTW 3/25/12
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71 Join Date: Nov 2011
Hey Nate, Can you give me the info on where I can get these hood pins please?
02-26-2013, 09:52 AM | #1902 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
02-26-2013, 11:30 AM | #1903 |
[COTW 5/12/14]
Steering rack looks sooooooooo goood
02-26-2013, 07:38 PM | #1904 | |||||
Here is a pic of two of the guys that were helping me. Tom, the owner, is not in the picture, but he has definitely been instrumental in helping me out. Quote:
http://ringbrothers.com/unviersal-ro...n-kit-943.html Quote:
By the way, I wrote out a rough spread sheet of everywhere that i am losing weight on the car. I didn't think to weigh everything as i go like you have done, but i have gotten the weight of particular parts online through the forums and manufacturer websites. If the data i have gotten is true, i should have lost at least 385 lbs so far, including near future plans, 120 of those lbs being unsprung weight. I bought a scale to start weighing some more things as i go. The CF fenders are about 3lbs lighter each for those who asked. ********************************************* QUICK UPDATE: Did some work creating a fan shroud for the radiator today. The piece is very nice as is, but for my project, I wanted a cleaner look. My plan is to cover up the rad fins completely, with only the fans visible. I will then mount the fans to the shroud by fabricating a 3 spoke mount and welding it to the fan shroud. I took some measurements and made a template out of thin cardboard for when i go to the local metal fab shop tomorrow. Last edited by Moreno1; 02-26-2013 at 08:47 PM. |
Thread Tools | |
Similar Threads | ||||
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
