Old 07-18-2015, 03:43 PM   #183
Twin Town Terror
Twin Town Terror's Avatar
Drives: 2013 Camaro 1LT
June 6th 2015: Rock Falls Raceway Rock Falls, WI
66 deg. F
Humidity: 62%
Dew Point: 45 deg.
Pressure: 30.18" steady
DA: 1210'
Modifications to car: CAI cold air intake, Elite Oil Catch Can, Elite Clean Side Oil Separator
Number of passes: 9
Avg. 60': 2.172
Avg. 1/4 Mile ET: 14.443
Avg. 1/4 Mile MPH: 96.64
July 18 2015: Rock Fall Raceway Rock Falls, WI
80 deg. F
Humidity: 75%
Dew Point: 68.7 deg.
Pressure: 29.78" steady
DA: 2708'
Modifications to car: CAI cold air intake, Elite Oil Catch Can, Elite Clean Side Oil Separator, ARH Catless Downpipes, Magnaflow Resonated X Pipe
Number of passes: 10
Avg. 60': 2.248
Avg. 1/4 Mile ET: 14.472
Avg. 1/4 Mile MPH: 97.581
Lost .076 of second in the first 60' but only lost .029 at the stripe. Picked up a whole mile per hour. Even in the much worse weather conditions it's clearly making a lot more horsepower in the upper RPM range, but looks like it lost low end torque.
Obviously a tune most likely would not only get the low end back but also improve the horsepower gains even more. However, I think I am going to go with the Jac-Fab Intake Spacer first. I really want the tune to be the very last step.
Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, TTT rear seat delete, Nitrous Outlet plate kit, 125hp jets.
Twin Town Terror is offline   Reply With Quote
Old 07-19-2015, 01:26 AM   #184
Twin Town Terror
Originally Posted by Sanjay Collins View Post
Are you going to remove the mufflers or get aftermarket ones now? I'm curious how it'll sound after that.
To be honest with you, I want to get the wheels first just because they would look better and faster... And probably improve the ET the most. Seriously.
But now, knowing what I've learned, I'm probably going to remove the mufflers, then get the JacFab spacer until I can afford the cat back Magnaflow system.
Old 07-19-2015, 01:38 PM   #185
15CamaroRS2LT
15CamaroRS2LT's Avatar
Drives: 2015 Camaro L99-1SS/RS CRM
I put the "axle back" Magnaflow on my 2015 and had no difference in the ET at all. As a matter of fact I raced with less fuel (80 lbs lighter according to the track scale) and ran the exact ET to the hundredth, that my TAG weatherstation predicted using the old information...14.551 @ 96.03 @ 4005 lbs....96 degrees - 37% humidity - 30.10 Baro - +2463 DA..(Englishtown, NJ after Nationals)...against a prediction of 14.558. The sound was better, which is why I had them installed, but performance did not improve at all, so I'd go with the wheels first also.
2015 Crystal Red RS V6....14.52 @ 95.34 CAI cold air package, 642 mile on odo..Best ET 14.41 @ 97.12....sold 7/29/15
2015 Crystal Red 1SS/RS..A6..11.31 @ 119.76...4065 lbs...Ebay cold air kit, Pat G tune, MT drag radials, TSP 1 7/8" headers w/cats Circle D converter sold
2010 Victory Red V6 - Auto
15CamaroRS2LT is offline   Reply With Quote
Old 07-20-2015, 12:34 PM   #186
Twin Town Terror
Don't forget to take out the spare and the jack.
Old 07-20-2015, 08:31 PM   #187
15CamaroRS2LT
That is something that I did not due and my car has the optional spare and jack ($150 option) so I will get around to that after the issue with the "used" Solo HFC gets resolved. On your car, did you have the spare tire or the air pump kit?
Old 07-21-2015, 05:29 PM   #188
Twin Town Terror
Spare tire.
Old 07-22-2015, 08:09 AM   #189
15CamaroRS2LT
Twin Town Terror
PM sent
Old 08-22-2015, 08:39 AM   #190
Twin Town Terror
https://youtu.be/n5A4MTAG3Fk
I made a new video that you can hear better. My editing software wasn't working so its uncut straight from the camera. My setup has changed a bit since the last one also. I found a magnaflow catback kit for half price on Amazon so I pulled the trigger.
Old 03-26-2017, 02:17 AM   #191
Jc_SourPatch
Drives: 2014 2LT Camaro RS
Just installed ARH catless down pipes and let me tell you they are loud nest thing I'm doing to install x-pipe
Jc_SourPatch is offline   Reply With Quote
