01-04-2013, 05:15 PM | #15 |
#15 to original post is most crucial.....never thought of this even though the bike is in already in winter and "storage" mode with the insurance....
01-25-2013, 09:19 AM | #16 |
I'm an Engineer
I'm going to be in school for the next three months. My only option is driveway with a cover on it...anything in particular I should keep in mind?
01-26-2013, 06:13 PM | #17 |
Dry Gas.........
http://www.ehow.com/how_5095102_use-fuel-additive.html more article out on this subject. Anyone uses this? |
02-14-2013, 01:14 PM | #18 | |
Drives: '11 2SS/RS L99, '12 2LS LFX Join Date: Jul 2010
Your best bet, good coat of wax and leave it in uncovered. |
02-27-2013, 09:54 PM | #19 |
CocoaKid
Hi! I live in Canada and I'm stoked on finally being able to drive my Cammy more often than not!
My question is kind of opposite to this, basically I want to know how to keep my trusty little Altima going strong over the summer, as I won't be driving him as much, but it'd break my heart of something went wrong. Got me through the winter with no problems, and probably saved my life Basically I was thinking of oil change, good wash, coolant so far. I'm a bit new to the in and outs of cars, I just want to make sure he's still around when it gets cold again! |
02-28-2013, 08:20 AM | #20 | |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
02-28-2013, 04:47 PM | #21 |
CocoaKid
Awesome, thanks a lot!
07-25-2013, 05:42 PM | #22 |
Drives: 2010 Camaro SS Join Date: Jul 2013
This is how I stored my GTO last year the camaro will be the same.
Sent from my SCH-I545 using Tapatalk 4 Beta |
07-31-2013, 08:41 AM | #23 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
1) The worst thing you can do to a stored car is start it up ever couple of weeks. Let it sit ! 2) I always change the oil and filter AFTER winter storage, not before. Again, just my opinion.
09-10-2013, 09:56 PM | #24 |
Drives: 2014 Join Date: Sep 2013
Great info....can you recommend a good car cover for Wintah outside storage in NH ???
10-22-2013, 07:03 AM | #25 |
Drives: 2013 2SS/RS/1LE Join Date: Mar 2013
I read that carpet pads can absorb moisture and aren't recommended for storage in areas that aren't heated. Seems logical, though I'm not sure how much of a concern it really is. I used 1" insulation foam instead, thinking it would give a better thermal/moisture barrier and cushion to avoid flat spots - though that also seems to be a non-issue for newer tires.
10-22-2013, 10:03 AM | #26 |
10-22-2013, 01:12 PM | #27 |
Should windows be all the way up or cracked open for ventilation? The gas tank looks like its plastic. Is that just a plastic cover over a metal tank?
10-22-2013, 08:19 PM | #28 | |
Sent from my SCH-I545 using Tapatalk 2 |
Thread Tools | |
