11-12-2012, 03:40 PM | #15 | |
Drives: pleather and Chiclets Join Date: Mar 2012
11-12-2012, 04:02 PM | #16 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
IOM ninja hit the nail on the head.
Mustang will be smaller/lighter...and the new Camaro based on the Alpha platform will also be lighter and based on the ATS, should be around 3,400 lbs in base trim...maybe even less since the ATS base is under 3,400 lbs. Both cars should be killer performers....even better than the current cars which are already awesome. For me, it will come down to the looks of both cars. One other thing I'd like to see is a version of the LFX V6 with 330 - 350 stock HP being available in the new Camaro, but not sure that will happen since I'm sure we will see a turbo 4 and a V8.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
11-12-2012, 04:28 PM | #17 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
I wouldn't expect a 6th gen to be available until early 2015 at the earliest. I think GM is going to release after the next gen Mustang to gain a big advantage and at the least make faster cars.
Also keep in mind that GM is doing very well so they probably have more on the table to use than Ford. Regardless, I expect both cars to be similar to the current situation. Close in performance by mere tenths. |
11-12-2012, 04:46 PM | #18 |
Drives: 2014 2ss/RS 5th gen Camaro #2 Join Date: May 2012
Maybe Im Misinformed but wasn't there talk of them putting a turbo v4 in the base model mustangs instead of a v6?
11-12-2012, 05:53 PM | #19 | |
Drives: 12 MP4-12C, 16 Quattroporte Join Date: Mar 2012
11-12-2012, 06:12 PM | #20 |
Drives: 2012 45th Vert 2LT/RS Join Date: Apr 2012
In this thread:
"I think" "I heard" "I believe" "I expect"
11-12-2012, 06:57 PM | #21 | |
Drives: 2012 SS LS3 | Silver Frost Metallic Join Date: Apr 2011
I've been a die-hard Chevy guy since I started driving, but the problem is that Ford pushes the Mustang's performance across one platform whereas Chevy pushes their's across two. Chevy could build a Camaro that blasts the Mustang, but then it'd be called a Corvette and they don't want to do that. I'd swear that GM purposely engineered slow-me-down weight into the 5th gens just to keep those lines from blurring between the Vette and the Camaro. Meanwhile, Ford only has the Mustang which has many models that outperform the Camaro in almost every way.
__________________________________________
Ironman John |
11-12-2012, 07:10 PM | #22 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Do you mean this 50th anniversary Mustang or the next generation of Mustang?
http://www.mustangheaven.com/2012/20...-holman-moody/
11-12-2012, 08:18 PM | #23 | |
They didn't follow ford when they gave Camaro its rear suspension. Or the zl1 with its magnetic suspension. Staying with the zl1 it outclassed its competing mustang in every aspect aside from quarter mile, while still being more affordable. I don't know what streets you are on but I have yet to see a board with quarter mile times |
11-12-2012, 09:29 PM | #24 |
Drives: the 2nd amendment home Join Date: May 2008
If you want to know more about the next gen Camaro, just google CADILLAC ATS
-- Benjamin Franklin |
11-12-2012, 10:04 PM | #25 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
Way too early to predict how well the 6th gen Camaro and next Mustang will sell.
It's safe to bet the next Mustang will sell like crazy on its first year though. The Camaro won't have a chance in the sales war that year. The Camaro will likely match (or better) Mustang sales though when the 6th gen is released. The projected release years of the 6th gen Camaro and next Mustang gives the Camaro an advantage in the long run.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
11-12-2012, 11:22 PM | #26 | |
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500 Join Date: Sep 2010
And again the GT500 and ZL1 is a toss up on a road course. It all depends on the driver. Also to your comment "Don't forget that the same level competing mustang costs more across the board." That really only applies to the Boss and GT500. Every other Mustang costs much and comes with Standard HID's. When people say that Chevy follows Ford they mean because Ford always seems to make the first move with the Mustang. You'll see what people mean if you look at the fact that the Camaro up until the ZL1 didn't handle very well and Ford despite having put a Stick Axle in the Mustang made it handle quite exceptionally for what it is before the before Chevy made the Camaro ZL1 do what it does. Ford likely never had the plan of making the Mustang handle the way it does as most people use Pony Cars for Drag Racing. Also as per your last sentence, last time I checked most roads don't have hairpin turns that you will take at 140 km/h. Last edited by The IOM Ninja; 11-13-2012 at 01:48 PM. |
11-12-2012, 11:25 PM | #27 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Not to mention the lack of a Z/28. |
11-12-2012, 11:38 PM | #28 | |
If Chevy truly wanted to make a competitor to the Boss 302 they would add adjustable suspension to the 1LE, in my opinion, or as you said brought out a Z/28. Not to start a war or anything but Chevy didn't seem to start caring about Fifth Generation Camaro owners until more recently. Ford, I'll give Chevy the fact that the Camaro hasn't been out as long, has a lot more parts available for the Mustang from the Dealer. |
Thread Tools | |
