Old 07-18-2013, 01:06 PM   #15
white ZL1
Drives: none
Originally Posted by steveo9043 View Post
Ok so there is a debate going on another forum about how a cam on a L99 car will not net you more then a couple of tenths at the track.
This debate is about a cam only. Not a cam and stall combo, not cam and heads, etc
Is there anyone who has a L99 car with a bolt on car and 1/4 mile times then did a cam only (either LS3 conversion or VVT) and 1/4 mile times?
So....stock cammed L99 with stock heads and converter vs cammed L99 with stock heads and converter?
Yeah....I'd say a cam that can play well enough with the stock converter to cut a decent 60' might only be worth 2-3 tenths over the stock cam. That wouldn't surprise me one bit.
white ZL1 is offline   Reply With Quote
Old 07-18-2013, 01:10 PM   #16
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
Stock cammed L99 with bolt on's and an aftermarket converter
vs
aftermarket cammed L99 with bolt on's, aftermarket converter (no heads, no intake, etc)
Just the cam being the only difference.
2012 45th L99 SS-Cold air inductions CAI-Dynatech LT's-Solo mach XL catback
333hp/341tq (before LT's)
steveo9043 is offline   Reply With Quote
Old 07-18-2013, 01:13 PM   #17
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
this is from Rhino's build
7. Torque Converter. Since the car responded so well to the bolt on mods, I wanted to start working on the rest of the setup to maximize what power was already there. I installed a Yank SS32000 and borrowed some slicks on 17's (thanks Gretchengotgrowl). 388 rwhp
8. 3rd Track visit. Memphis here we go again! Weather was hot and humid. Bolted the tires up, and while the car was deadly consitent, it only picked up 2 tenths. The converter was too tight for my liking and it only 60'd mid 1.7's. Best pass of the night was 12.2 at 112. :(
9. Cam/springs. Enough of the bs, I wanna go fast. I really thought the bolt-ons and stall would land me in the high 11's, but it wasn't to be for me with that converter. So I installed a Mast SS VVT grind. 230/244 on a 111 lsa, along with beehive springs and a afm delete. 457 rwhp
10. Ported tb and ported intake. I decided to try and help the cam breathe up top by doing some porting work on the intake and throttle body. It paid off by helping power throughout the curve. 474 rwhp
11. V6 brakes, had to make room for track friendly wheels!
12. Track time again! Went to memphis to rip the car with the cam setup. I was very very impressed despite the weak 60'. 1.7 60', 11.39 at 121.42! Dyno numbers the day before the track run were 468 rwhp.
looks like he went 12.2 with slicks stock cam and a 3200 verter.... down to a 11.39 with the cam and yes a ported TB and stock Manifold but the gains are minimal from that. So even adding 1/2 a second onto his time to compensate for the differences... that shows what a proper cam can do with stock heads
xjer22x is offline   Reply With Quote
Old 07-18-2013, 01:19 PM   #18
steveo9043
steveo9043's Avatar
he picked up .8 with ported throttle body, ported intake, Track friendly wheels and a cam.
But yes stock heads.
Id say .3 of that was the throttle body, intake and wheels (not sure what track friendly wheels means in this, could be lighter wheels, skinnies up front etc) so I would say .3-.5 from the cam the rest from the other.
I'd be happy with that.
Old 07-18-2013, 01:20 PM   #19
xjer22x
xjer22x's Avatar
Thats all i am trying to point out lol it can be done.
Old 07-18-2013, 01:21 PM   #20
steveo9043
steveo9043's Avatar
yeah i know. I am just looking for evidence! lol
Old 07-18-2013, 01:27 PM   #21
xjer22x
xjer22x's Avatar
i hear you. i like evidence too. I just know i have seen it and saw it being done a few times. But glad you can see the possibilities now.
Old 07-18-2013, 02:49 PM   #22
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Well not that it helps any now, but I will be doing this exact experiment next spring. I am full bolt ons with an aftermarket converter already. I have a couple more mods that I'm doing this year, (gears and PI), so then I will have my absolute fastest (bolt on only) time for my car. Next year I will add JUST the cam to my current set up and I AM expecting another .5 faster. Only time will tell.
This year however my goals are different. Just wanna max out my bolt on only w/stock cam set up.
Camarojt is offline   Reply With Quote
Old 07-18-2013, 02:51 PM   #23
steveo9043
steveo9043's Avatar
What are you running if you don't mind me asking.
Old 07-18-2013, 02:54 PM   #24
62nalide
62nalide's Avatar
Drives: 2013 SS
And we thank you for your experiment too
Hope by October I should mimic your mods!
62nalide is offline   Reply With Quote
Old 07-18-2013, 02:55 PM   #25
Camarojt
Camarojt's Avatar
1/4 times?? 11.85 is my best so far. Should do better this year with gears PI and -negative DA!
Old 07-18-2013, 02:58 PM   #26
steveo9043
steveo9043's Avatar
Sounds good!
My plan is to stall the car with a trans cooler then tune this fall.
Over winter I want to do a VVT cam with just replacing the AFM lifters.
then see where things are.
Old 07-18-2013, 02:59 PM   #27
Camarojt
Camarojt's Avatar
Haha! Mimicking is the sincerest form of flattery!!
With your dyno numbers so far I do believe you have the potential to draft right behind me and slingshot past me! WAIT....did I just do a NASCAR reference?? Dammit BaltimoreJohn will be all over this thread if he searches and sees NASCAR!!
Old 07-18-2013, 03:13 PM   #28
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
I have ran 11.62 @ 117.90 with a 3200 Yank converter and bolt-ons only and will be installing a VVT cam shortly and I expect to run .5 to .6 tenth's faster in good air in the fall!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
