08-24-2015, 08:55 PM | #15 |
Drives: 2011 SS LS3 Join Date: Nov 2014
Thanks I will try to have them re balanced tomorrow, I am sure of one thing if anybody drove my car...they would notice it. You can visually see the steering wheel shimmying back and forth between the mph "shake zone".
2011 LS3, 2SS/RS. Stainless X-pipe, SLP skip shift eliminator, RotoFab CAI, Super 44 Axleback.
08-24-2015, 08:57 PM | #16 |
Norcal Camaros
Drives: 2010 Red Jewel 2SS L99 Join Date: Mar 2012
Just a thought here as looks like you have had a rough go at this. Since you went from old (guessing bald) tires to new tires with lots of tread, maybe just the feel of the ride is now different? All tires will feel different do to the tread pattern. But either way you know your car better than anyone else so good luck. Just my .02
Blaque Diamond Wheels BD23's 20x10, Hankook V12 275, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms,
08-24-2015, 09:25 PM | #17 | |
Drives: 2012 Camaro 1LT Join Date: Dec 2010
2012 Camaro 1LT
Summit White/Black Rally Stripes Ordered 8/21/11, built 9/22/11, delivered 10/7/11 |
08-24-2015, 11:20 PM | #18 |
Well mine is in no way normal..I am new to Camaro but not to high performance cars (owned 13 Mustangs prior). Mine was side to side shaking with the old tires then put new ones on and still shaky..Note: the car did not shake when I bought it 38k miles now at 49k miles shake,shake,shakey wheel. I have not hit anything or damaged and parts.
08-25-2015, 01:39 AM | #19 |
Drives: Never just fly under the radar Join Date: Jul 2015
When shops put wheels on some of them use air impacts that torque from 250lbs up to 1000lbs. Although the 250-400lbs impact is more common. Usually a wheel torques spec is around 80-100lbs. The old impacts didn't have the higher torque of the newer ones and most wheels where steel. This has caused problems more lately over the years and people are becoming more aware of over torquing the lugs. The over torquing of the wheel causes the rotor to warp and the car to shimmy especially when braking. Took me 2 years as many vehicles and three sets of tires at the wrong shop to figure it out. Of course the shops not owning it.
Recommendation when installing wheels especially newer style lighter ones always use a torque wrench not an impact.
Old Skool |
08-25-2015, 01:42 AM | #20 | |
I have only had one occasion where re-balancing under load helped but did not completely fix the issue.
Old Skool |
Thread Tools | |
