07-08-2016, 12:22 PM | #15 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
That's not normal. People have had their shocks replaced under warranty and had the issue go away.
My thoughts on some things:
07-08-2016, 05:23 PM | #16 |
Drives: 2015 1LE 2SS/RS CRT NPP AYZ NAV SUN Join Date: Aug 2014
Same thing happens to me when I go over a transition in the pavement. Only hear it on the passenger side. My dealer will be getting a call soon.
1989 IROC Z L98. 2015 Silverado LT. 2015 2SS 1LE. |
07-08-2016, 07:24 PM | #17 |
Mine was only on the passenger side as well.
07-09-2016, 11:33 AM | #18 |
Is there a bulletin or something regarding this? Mine does this, but only in very sudden transitions that cause the wheel to drop out from under the car quickly. I assumed it's just the limit of the shock travel and the upper shock cap is hitting the mount. I can tell because the rubber ring is leaving a telltale black mark on the shock tower.
It's done this since I've owned it and I generally just avoid the bumps I know will be an issue. If there's a warranty claim here, I definitely want it fixed, but I would like to know how to reliably get the dealership to address the issue
07-09-2016, 01:00 PM | #19 |
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jul 2014
Really? Uh oh.. I'll get loud bangs when I go over a hump or bump too fast, but the car still feels solid under abuse and doesn't make noise during sharp turns. I'll get it checked out anyway better to be safe than sorry.
07-09-2016, 02:16 PM | #20 |
When mine was replaced, problem solved. I have not had one issue since.
07-09-2016, 05:47 PM | #21 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2016
Mine is banging really loud. Front oassneger side. Tiny sharp bumps normally cause it. Started about two months ago. Sounds like the suspension bottoming out.
Next time I go to the dealer I'm going to have them look at it. |
07-09-2016, 06:01 PM | #22 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
Anybody know the PN#'s for the front left & right struts and rears shocks????? I'm going to be doing lowering springs next month .. And ,I thought why not replace them the same time!!
07-09-2016, 06:07 PM | #23 |
Those with issues. Dont forget the 1st time i took mine in they couldn't find anything wrong with it. It was only after taking the service manager with me that he then heard/felt it. It was at that point he had the tech pull the strut off, and it was then that they found the issue.
07-09-2016, 06:09 PM | #24 |
Drives: '23 LT1 A10 Join Date: Oct 2015
I have had some loud bang from mine too. Sounded like the right front.
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
07-10-2016, 12:13 AM | #25 |
Drives: 1967 GTO Join Date: Oct 2015
My brand new 2015 even did it on the test drive. We all bought performance track cars. Either stick a tampon in or go buy an SS haha
07-10-2016, 01:26 PM | #26 | ||
Drives: ‘13 1LE Join Date: Jul 2013
Might be different, or might be the same thing, but simply the strut in question is not @ 100% fail, but more like a lower percentage%. There is literally ONE BUMP WITHIN A 100KM radius, that I will experience this issue, emanating from the drivers side, and ONLY if travelling at a speed between 95km/h-125km/h, over that sole bump. NO exaggeration, one bump, one speed range, and it seems one ambient temperature range as well. It seems to happen when it's hot outside, and never when cool or cold. I also don't get the full "windshield_might_break_strut_through_hood effect, lol, but it is still loud enough to cause one, like a passenger to say to me wut wuz dat politely, lol. With the above criteria that i have to work with, it is near impossible for me to prove this to a tech at the dealer. Ironically, I almost wish my issue was worse, and more in your face. |
07-10-2016, 04:51 PM | #27 | |
Drives: 2014 Camaro 2SS 1LE /2011 2LT Join Date: Sep 2015
07-11-2016, 03:21 AM | #28 | |
Drives: 13' 1LE Join Date: Apr 2012
2 bumps in town do that.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
Thread Tools | |
