10-20-2021, 05:18 PM | #15 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
They did improve the spring as the designer argued that the spring has an advantage with lag opposed to no lag on a pin over a lifetime. Remember they were thinking 10 years or 120K miles. Yep I agree if removing the ATI you might as well rebuild it.. |
10-20-2021, 10:59 PM | #16 |
KaBoom1701
Got some parts today.
Mods:
10-21-2021, 10:37 PM | #17 |
KaBoom1701
Mission accomplished!
Mods:
10-22-2021, 05:47 AM | #18 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Nice job. Now send it out to get ported while it’s off.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
10-22-2021, 08:51 AM | #19 |
KaBoom1701
Thought about it. Lol
I need to keep parts for CA smog so I'll need another snout or complete SC unit as a donor for porting. I just slapped the updated solid iso coupler from Eaton in there for now and buttoned her up. Gotta finish plugs, wires and long tube headers and flash back to custom tune today. My daughter says my car lost her growl. Lol. Can't have that.
Mods:
10-22-2021, 10:24 AM | #20 |
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1 Join Date: Oct 2009
Did the tite-reach work to get at the back bolts of the supercharger lid?
10-22-2021, 10:57 AM | #21 | |
KaBoom1701
I ended up using the rubber mallet wedged between the SC lid and hood to gain the space I needed. Then used a 1/4 drive socket/ratchet combined with a 1/4 swivel joint. I also had a these metric flex head ratcheting wrenches that worked great on getting the bolts tight. Combined with a handy magnetic pen to help set the screw and prevent it from falling down into the back on the engine. Pro tip - secure your 10mm wrench with a string.... that way when/if it falls behind the engine you can retrieve it easily. lol Honestly beside the bolts on the back of the SC lid being a PIA the whole time is spent removing/cleaning the old RTV seal from the SC housing and snout. That stuff takes forever to remove. I wanted to make sure I had a good seal for the new RTV before reassembly.
Mods:
10-22-2021, 04:40 PM | #22 | |
Best tool in my bench... https://www.harborfreight.com/14-in-...het-67994.html |
10-22-2021, 05:14 PM | #23 |
KaBoom1701
Mine is the magnetic pen I have. I grab more dropped bolts and wrenches with that thing. Lol
Mods:
Thread Tools | |
