11-16-2021, 09:55 AM | #15 | |
Drives: 2013 ZL1 Join Date: Jan 2020
Id prefer using the TI pumps over the DW stuff. Luckily you did the fuel door mod to address any issues that might pop up. |
02-28-2022, 09:58 PM | #16 |
Drives: 13' ZL1, 04 SS Silverado, GS-F Join Date: Feb 2020
Squash customer service is SHIT!!!
02-28-2022, 11:14 PM | #17 |
I've had good experiences with Deatschwerks customer service. They stand behind their product too. My pumps so far are doing what they're supposed to.
03-27-2022, 07:40 PM | #18 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jul 2019
How long does a pump usually last? When you change pump do you need to retune for that pump?
06-13-2022, 12:43 PM | #19 |
Drives: Procharged 2011 Camaro SS Join Date: Jun 2022
900 LPH for under $1,000
I know I’m about 6 months late to the party here, but if someone looks up this thread at a later date this may give them even more useful information. I have a 2011 Camaro SS with Procharger D1SC with 14 lb. Pulley, ID1000 injectors, Fi Tech ultimate LS intake and fuel rails, Granatelli 102 mm throttle body running E85. I switched out the ZL1 dual 255 LpH in-tank pump with a Hinson Motorsports dual 450 LpH in-tank pump wired with a Fore innovations FC3 module to stage the pumps. Pump 2 is engaged by 5 psi Hobbs switch (Honeywell 77030). Hinson motorsports dual 450 LpH in-tank pump was $750. Fore Innovations FC3 module is $250. 5 psi Hobbs switch $70. Great set up. I highly recommend.
06-13-2022, 01:40 PM | #20 |
Your fuel regulator should be doing the work.
07-20-2022, 02:12 AM | #21 | |
Drives: 2011 Camaro SS Join Date: Oct 2021
07-21-2022, 09:47 AM | #22 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Did you ever get this fuel system built and running?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-09-2022, 11:26 AM | #23 |
02-05-2024, 08:37 AM | #24 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Well, how did it turn out?
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Thread Tools | |
