#267 |
![]() Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
416 TT 6266's M6 - SAE numbers on 93 octane and Meth
8psi 15psi 18psi 20psi (partial pull but let out due to lean A/F) These pulls were made with ZL1 pump, ADM FPCM and 1000cc FIC's Dual Nozzle (#15 and #10 nozzles) Meth injection |
#268 |
These were the raw numbers for the 18psi and 20psi pull.
#269 |
One Year of Silence, Lets get it going again!
I read through this post and liked it. So I thought I would add my info to it.
My build is centered on a 2013 ZL1, but I think others will find it helpful. I used the stock supercharger that I ported and over driven 40%. Short list of work and parts on the LSA engine. Wisco Pistons - Comp Ratio 9.50-1 Eagle ESP Rods - Upgrade ARP 2000 Bolts Texas Speed Ported my LSA Heads ID 850 Fuel Injectors Ported Supercharger and Snout - 40% over driven LS3 Throttle Body Custom Cam - close to a BTR stage 3 Johnson Roller Lifters GM Hollow Stem Intake and Inconel Valves BTR Ti- Spring Kit CHE Trunnion Bushings ARH 17/8" Long Tube Headers Livernois Dual Fuel Pump - came up short for my HP needs Boostane Octane Boost - 103 Octane Level Here is my Dyno Pull on pump gas with Boostane (103 octane) 765whp at 6500rpm boost was 16.75psi on the (Heartbreaker) Dyno Dynamics dyno. On a Dynojet dyno that would be 933rwhp and 1,097hp at the crank. Not to bad for a do it yourself build in my living Room. This car and engine (other than block machine work) has never been worked on by a shop! Check it out at: https://www.camaro5.com/forums/showt...=571243&page=1 Including what a Dynojet run would have looked like. |
#270 |
Nice numbers… but you aren’t anywhere near 933rwhp on a dyno jet. You’d be lucky to crack 800rwhp with that combo.
#271 |
![]() Drives: Red Jewel Camaro SS Join Date: Mar 2014
At 1100RWHP so far.
50/50 of 91 pump and MS100 for fuel,and meth. Gonna try some ethanol next year. Still on the stock AGP Y-pipe 62/62 and stock 90mm TB. 6L90 with ZL1 diff and heavy 20" wheels.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
#272 |
#273 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Latest setup:
TMS 427 with their Stage 2 centri cam FED M311 heads TSP 2inch header 3 inch exhaust ESS Tuning G4-95 Supercharger with 207mm lower/90mm upper Edelbrock Pro Flo XT NW103 TB E75 15' MT ET R Still running the same tune that JRE did for my last blower. You can see it could use a little clean up on the MAF in the higher hz areas. I used a new source for my FPR, and I was only seeing fp rise to 74psi, so my injectors are maxed. I usually see 80psi. I moved the source back to the intake manifold, so hopefully that's fixed. Run 1 with ESS air filter and piping. Run 2 with no air filter or piping Run 3 with ESS Bellmouth ( I didnt use a clamp, and it flew off around 6900, you can see the boost dip) Overall I'm extremely please with this kit. Something that sets it apart from the rest (besides the belt wrap), is the intake temperature. All three pulls peaked at 105-106 degrees. I do not have meth on the car. It was a nice day in Florida, but still 90 degrees in the dyno room. Pretty cool. Hopefully late 2022, th400. https://youtu.be/nEhTwwtChFI
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... Last edited by eLeSthree; 01-27-2022 at 05:41 AM. Reason: Heads |
#274 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
After having the setup and donking on the tune myself year after year, figured I'd actually go in and see what the dyno says. Guy I was renting the dyno from said there's plenty more available by adding more timing, leaning out fuel and running higher RPMs. I just wanted a safe high-power car so I didn't go for more (yet). Maybe another day...
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
Thread Tools | |
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4242 | 02-17-2014 08:57 PM |
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
Really? Why is the DealerInfo Thread Gone? | renderinfo | 5th Gen Camaro SS LS LT General Discussions | 2 | 02-11-2009 08:01 AM |
Changing Photoshop Thread Format | headpunter | Site Related Announcements / Suggestions / Feedback / Questions | 20 | 11-06-2008 05:40 PM |
