Old 08-16-2013, 12:30 PM   #393
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Hey ofer, without searching through this huge thread, where does the loose red wire attach to on the cable that attaches to the camera? I'm assuming the reverse lights but just want to be sureName:  ImageUploadedByTapatalk1376670657.132051.jpg
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 08-16-2013, 12:59 PM   #394
OmniCamaro
US Veteran
OmniCamaro's Avatar
Originally Posted by OmniCamaro View Post
Hey ofer, without searching through this huge thread, where does the loose red wire attach to on the cable that attaches to the camera? I'm assuming the reverse lights but just want to be sureAttachment 546254
Ok, since I have the 2SS this wire is not used. Thank you Ofer!
Old 08-16-2013, 03:13 PM   #395
OmniCamaro
US Veteran
OmniCamaro's Avatar
How to install Ofer's backup camera retrofit
All done and working great! I did forget to put something back on though, oops! Hope I don't get pulled over before I get back home!!
**edit: made it home with no incident**
Old 08-16-2013, 03:16 PM   #396
OmniCamaro
US Veteran
OmniCamaro's Avatar
Awesome customer service as well! I called twice and they knew exactly what to do on both occasions. Thumbs up!
Old 10-15-2013, 02:58 PM   #397
KalCorp
Space Coast Camaros
Drives: 2012 Camaro Vert
Is there one of these that works for a convertible? i think the mirror is different.
I got a 2011 2LT/RS vert
KalCorp is offline   Reply With Quote
Old 12-16-2013, 07:17 PM   #398
mike 2010ss
Drives: 2010 SS
I I have this same camera but not sure which wires are spliced to where.Not wanting to send voltage to somewhere it doesn't need to be.
mike 2010ss is offline   Reply With Quote
Old 12-24-2013, 06:34 PM   #399
luischou
Drives: white rabbit
help
I already bought from Gen5diy, mine is this one wire and camera. how should I do? 2011 LS
Originally Posted by hcso617 View Post
I received my kit yesterday. I have a 2011 LS. Please tell me if I'm reading the information correctly.
The LS does not have power for the camera from the mirror wiring harness. There is a red wire looped out of Ofer's harness about 20" from where it plugs into the camera. I use this red wire to tap into the green wire on a reverse light, and make all other connections mentioned?
luischou is offline   Reply With Quote
Old 12-25-2013, 07:41 PM   #400
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Pull the red wire out, and t-tap it to your backup lights, that will power the front side of the harness and if you got the mirror harness to it will power the mirror when you need it, if you need more help you can call me.
Old 01-13-2014, 06:50 PM   #401
Dave1222
Drives: 2010 CAMARO SS/RS
Any chance this kit will be offered with a newer style (or more sleek) mirror in the near future?
Dave1222 is offline   Reply With Quote
Old 01-15-2014, 11:41 AM   #402
2SSRS@Gen5diy
what mirror did you have in mind?
Old 01-15-2014, 09:59 PM   #403
Dave1222
Thanks for the reply. I guess something more similar to the LS frameless mirror you sell.
Old 01-19-2014, 11:46 PM   #404
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
I'm actually looking at a camera from an equinox. - it and it's bracket are one piece, and it's meant to snap in place from the outside/under (it goes in the liftgate handle on the equiniox) it's a little hard to see in the pics, but there are fingers on the sides of the camera that should hold onto the bumper plastic... and appears to have the right plug configuration
Toasty is offline   Reply With Quote
Old 01-20-2014, 09:57 AM   #405
2SSRS@Gen5diy
We have tryed for 2 years to make the 2012 Camaro mirror work in older cars with no luck, we think the BCM does not let it come on, so to get the BCM reprogrammed is not going to hapen.
nice find, but its the same camera as all the rest of the GM line, only the mounting is different.
Old 01-20-2014, 10:01 AM   #406
Toasty
Toasty's Avatar
I thought it might be, but from the part diagrams, its only a 1 piece bracket, and comes with camera.
Rear view camera and LCD mirror install on my vert. SUX2BU Camaro Convertible Forum 62 08-18-2012 07:40 PM
Backup camera install help. meschwenk Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 04-05-2011 09:16 AM
