07-14-2014, 08:56 PM | #29 |
Drives: 2013 ZL1 Join Date: May 2014
I also got the Planted brackets and they don't line up with the Cobra mounting points and I can't get the floor bolt to fit through one of the leg holes. Did you have any issues? Did you get the airbag light worked out?
07-14-2014, 11:10 PM | #30 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
They look great! Are they 6 way power?
07-15-2014, 01:54 AM | #31 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
It will fit the rear holes, but you have to put the Torx head floor bolt in at an angle and gently push it thru using a ratchet while turning. Kevin at RODZ did it. I couldn't figure it out either until I saw him thread it in. Have not put the resistors in yet as I have to get the Planted bracket slightly modified for extension rearward. Just pressed the acknowledge button on the signal arm to get rid of the "service airbag" light. The red airbag indicator stays lit until the resistor is installed. Keep me posted regarding your installation. Dick Gulstrand of Gulstrand Performance, and Mike Donatelli of RODZ trying to figure out how to use the Planted bracket with Cobra side mounts! Last edited by ZL1-V; 07-15-2014 at 02:12 AM. |
07-15-2014, 01:58 AM | #32 |
07-15-2014, 02:15 AM | #33 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
I really don't get power seats. Once you have it adjusted where you want it, it doesn't move.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
07-15-2014, 06:40 AM | #34 |
Seats look absolutely awesome!!
07-15-2014, 10:34 AM | #35 | |
Same here I am the only driver, and don't have to worry about readjusting the seat to my comfort level. I don't regularly visit places that require them but I now realize the added benefit of the fixed seat back and it's location. It will deny the over eager "parking attendant"/valet asking to park the car. |
07-15-2014, 10:38 AM | #36 |
07-15-2014, 05:15 PM | #37 |
Native Floridian
Nice!!! Are they as comfortable (padding) as Recaro's?
07-15-2014, 05:19 PM | #38 |
Native Floridian
My wife and I split driving the ZL1 as I travel a lot during the week. So the power seats just make it a lot easier to re-adjust.
07-15-2014, 06:10 PM | #39 | |
Drives: Camaro Join Date: Jun 2009
They look real good in there. Just make sure that your comfortable in the car when its all said and done. Metal can be cut and welded to death, so don't be shy and keep going till there where you want them. I've driven fabricators nuts in the past, and spent small fortunes getting things right. But when its right its all worth it. |
07-15-2014, 06:51 PM | #40 | |
Thanks Mike! Is that an offer in trade for me helping you coming up in October? It was so close to working initially but as you said welcome to the world of fabrication. Hopefully this first attempt will be spot on. |
07-15-2014, 09:15 PM | #41 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
ZL... Use your stock seat slider and drill holes in the top portion that slides. Buy cheap switch and use it to move forward and back, no need for planted seat base. Bolt up side rails from cobra and ur done. If u can get manual base even better no need for wiring work.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
07-15-2014, 09:54 PM | #42 |
Thread Tools | |
