07-17-2020, 11:30 AM | #29 | |
Drives: 18 1SS/1LE Join Date: Jun 2018
07-17-2020, 11:34 AM | #30 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
I mean the trusted engineers also let A8 shudder be a thing. I doubt not following the break in will have noticeable effects. If it does you wouldn't be able to prove whether it was because you followed the break in period or not.
I would still follow it. I followed the procedures very loosely. I definitely did WOT before 500 miles, but not like how I do it now at 4k. Warranty exists for a reason. |
07-17-2020, 12:57 PM | #31 | |
Drives: Fast if no one's looking Join Date: Aug 2019
I was easy on the car for that 500 miles, but Honda’s owners manual also states to leave the factory oil in as long as possible. The engine parts are coated at the factory and they want it in the engine as long as possible. So I waited till I was at absolute zero on my oil life indicator, approx 7500 miles, to do my first oil change. Today I can drive it hard, shift through the gears at redline, and it doesn’t burn or leak a drop of oil while still putting out every one of the factory 260 hp. Might have even gained a pony or two over the years - the engine is strong as ever. All the while giving me 24 mpg. Just sayin. |
07-17-2020, 01:26 PM | #32 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
This is one of those topics that are quite controversial with no clear answer.
One side believes the factory break-in procedures are valid and follow them (I'm in that camp) Another side will cite MANY engine builders that are on the side of 'run it like you stole it' right from the beginning and the rings will seat much better. They build race engines all day long and aside from a short cam break-in period, the hammer it forever. |
07-17-2020, 01:34 PM | #33 | |
I followed the owners manual to a T on the Camaro and just passed the 1500 mile mark last week. It took me since Feb. when I bought the car with 30 miles on it. So happy to have it out of the way!! Now if only covid didn't shut down my local track for the entire season |
07-17-2020, 01:36 PM | #34 |
Hot Camaro
Drives: '20 2SS Convertible 6MT Join Date: May 2020
07-17-2020, 01:50 PM | #35 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Gears need break in more than the motor. If you look at Cessna's break-in recs for new motors, it has to be done hard to seat the rings, so this isn't folklore. I don't think we need to worry about it though, it's been done for us on a dyno, so the motor isn't much of an issue. But, gears wearing in together optimally in the rear end and trans can be an issue. This also means engine builder's break-in will be different vs a complete car, when I've built new engines I've done a hard break-in with good luck, not going to redline immediately, but over the course of several pulls after it's warmed up. Finally, the rings seating in modern cars has made some massive improvements and manufacturers seem to either make engines with a perfect seal so the motor never uses a drop of oil, or this fails and it goes through far too much oil. IDK exactly what's going on there, but it's done in the factory and may look much different from what we know about traditional engine break-in.
07-17-2020, 01:58 PM | #36 | |
Hot Camaro
I also remember the dealership telling me very pointedly to NOT change that oil until the car told me to for the reason of additives in the oil from the factory. And, honestly, it's one of the reasons that I was hesitant to change the oil in the Camaro before the 1500 mile mark as I wasn't sure if maybe there were additives in the oil that GM wanted to remain in there for a minimum period of time (it doesn't seem that's the case, though). |
07-17-2020, 01:59 PM | #37 | |
Drives: 2020 Camaro RS Join Date: Oct 2019
These questions always intrigue me. Why wouldn't someone want to follow the recommended break in procedures? What is the benefit/gain from choosing to ignore/reject the procedures?
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
07-17-2020, 02:12 PM | #38 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
07-17-2020, 02:16 PM | #39 |
Hot Camaro
07-17-2020, 02:42 PM | #40 |
There are zero facts for either points. There can't be. You can never know if damage was caused by improper break in or not. This argument could go on forever. I play it on the safe side, some may not. Who cares.
07-17-2020, 02:51 PM | #41 |
I think it depends on whether or not you plan on keeping the car for a long time or not. If its a car you plan to keep and enjoy for many years, a proper break-in according to the manufacturer's suggestions is a really easy thing to do. And, it doesn't take long to get to 1500 miles. If you plan to keep the car for only a short period of a couple years or so, I guess drive it hard from the start. I just feel bad for the next owner who may have to deal with issues. This is one of the main reasons I wanted to buy new, and especially not one that was a previous rental. You know those were not broken in properly!
07-17-2020, 03:16 PM | #42 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I followed it(albeit not 100% perfectly) for the 1500 miles in the beginning FWIW.
I don't think GM uses special break-in oil as Honda does. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
Thread Tools | |
