06-08-2023, 01:45 PM | #29 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I saw something in one of the threads. Could you give me a link to the heat shield? I liked the idea. That was some kind of self-adhesive insulating film, wasn't it...?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
06-08-2023, 01:47 PM | #30 | |
I have already decided to buy it. But the GPI guys aren't talking to me yet. I need to negotiate the price of postage here to Europe
06-08-2023, 01:55 PM | #31 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Yes it's adhesive, I may have a link in the thread I started about intake. I am on my phone so it's annoying to try and search.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
06-08-2023, 02:06 PM | #32 | |
At rest... You'll put it here when you're on the computer. But I think the link wasn't there. I am mainly concerned with the thickness of the foil with insulation. I have no idea how much space there is under the intake.
06-08-2023, 02:18 PM | #33 |
https://gwatneyperformance.com/produ...ld-ls3-140021/. Heatshield Products (140021) I-M Shield Intake Manifold Heat Shield https://a.co/d/jlg1WIB
06-08-2023, 03:23 PM | #34 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
06-09-2023, 02:32 AM | #35 | |
This would be fine. Still no one called me. Maybe if they see bad English, they take it as SPAM message..? That's happened to me to.
06-09-2023, 02:51 AM | #36 | |
Perfect! Thank you
06-09-2023, 05:43 AM | #37 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
George,
As far as the heat shield here is some data. This is info from a data log I did & the air temp outside was about 60 degrees. The car was driven for 20 minutes normal to warm it up. oil temp was about 200. This was from the 4th wot in this particular log. Pretty impressive imo.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
06-09-2023, 05:45 AM | #38 |
According to your log it works well, Glad I added it the hardest part was getting the backing off of it.
06-09-2023, 07:26 AM | #39 |
I didn't see one this morning, so I'm assuming you got a reply. If you sent me one (and I didn't get it) let me know, and I'll figure out what's going on. You can always PM your e-mail address to keep it private, and I can e-mail you.
06-09-2023, 12:00 PM | #40 | |
That is very nice. I will definitely use this shield as well.
06-09-2023, 12:07 PM | #41 | |
That's weird Andrew. I wrote you an email today at 10am local time. Which, given your time difference, is 4am in the States. Can he please check it? I am copying the email here, in private messages. Otherwise, no one from GPI heard back. And that's what I wrote to them through their web form.
06-09-2023, 12:14 PM | #42 | |
Thread Tools | |
