10-12-2013, 04:10 PM | #43 |
I would second that. They did alot of R&D for the LLT.
10-12-2013, 07:43 PM | #44 | |
I run a business and sometimes things go wrong. I take it in the shorts and make it right with the customer because negative word of mouth is fatal and not worth whatever amount of money I'm trying to save by being a douche. Good job IPF.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
10-13-2013, 03:31 PM | #45 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Bearing issues are an old problem with any system. There are so many cheap bearings out there that I can see how this happened after I talked to an aircraft mechanic at work. I commend IPF for stepping up after seeing the returns and to Arno and the guys in Germany for getting some quality bearings in my hands quickly.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
10-13-2013, 11:55 PM | #46 |
Drives: 2012 LS M6, Black Join Date: May 2009
Vader, to answer a couple of your statements/questions, there are four bearings between the two pulleys, two in each pulley. Make sure you're getting four. And, yes, I believe the rear oh-2 sensors are turned off, but they are not reporting anything to the ECU except whether or not temperature is being reached for threshold catalyst kick-off. It shouldn't show up in an OBD-II scan.
What sort of visual inspection does CA have when it comes time for emissions? You could remove the compressor and intake/charge plumbing but leave the intercooler in place, as it is pretty well hidden, especially if the stock intake was back in place. The tune from IPF allows the engine to function JUST FINE without the supercharger running, so that should be O.K., too. Wouldn't take any more than an hour or two to do it, I'd think. Put the stock belt back on and you're golden. Fortunately, we don't have a visual inspection in AZ. We have an OBD-II plug-in for newer cars, rollers and a sniffer for older ones. This system will pass both. John B. |
10-14-2013, 03:07 AM | #47 | |
Drives: 2014 custom blue ZL1 Join Date: Jun 2011
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
10-14-2013, 08:51 AM | #48 |
Maybe Arno or Andy can chime in about the rear O2, I don't know how many "not ready" functions you are allowed to have and pass the inspection. There are a few state smog stations that still sniff no OBD reading
10-14-2013, 08:52 AM | #49 |
Or we can all move to Peoria. haha
10-14-2013, 12:04 PM | #50 |
I'm FROM Peoria. Illinois. You don't want to move there. Trust me on this one.
Peoria, AZ, founded by folks also from Peoria, IL has some nice areas. But I live in Phoenix proper. The big city. The mean streets. Right in the middle of town. Not only does AZ have nice weather and easier smog laws, but you can actually own and carry a firearm, if that's your thing. None of this magazine limit, magazine can't be in the gun, magazine can't be loaded, can't have hollow point business. But I digress. John B. |
10-14-2013, 12:53 PM | #51 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Fortunately my state also has pretty relaxed laws on emissions inspections (for now).
And even though we don't have any mean streets in S.Utah- residents are required to carry large capacity firearms with the most deadly projectiles available on the market (OK- not required but greatly encouraged!). Anyway, out of curiosity I hooked up the OBD reader to my car just to see what it says about readiness: MIL status- off (malfunction indicator lamp) Htd catalyst- N/A Sec air system- N/A AC refrig mon- N/A All other checks were OK (there is another separate "catalyst" check and it was OK). I don't know if a long GM style "drive cycle" would correct any of these or if the "refrig mon" would impact an emission check, but it sure blows cold air! |
10-14-2013, 02:52 PM | #52 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Mine
10-14-2013, 05:00 PM | #53 |
I'm in Massachusetts, the land of the second worse emissions check to California. Passed no problem back in March with all tests passed. The IPF tunes with readiness flags enabled worked great !
10-14-2013, 05:02 PM | #54 |
Are you guys all running the stock headers or do you guys have long tubes with high flow cats?
10-14-2013, 05:04 PM | #55 |
COTW 5/06/2013
LFX with SOLO high flow cats
10-14-2013, 05:22 PM | #56 |
Stock LLT with solo hi flow cats.
Thread Tools | |
