02-02-2017, 08:57 AM | #85 |
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow Join Date: Sep 2016
As far as i can tell, adding any decent power takes a gazillion $
02-02-2017, 09:03 AM | #86 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
The blower and IAT sensor get heat soaked and it references a different portion of the startup timing table. Have to play with it to get it right without affecting cold startup.
02-02-2017, 09:06 AM | #87 | |
having to do it with the front pulley adds cost because smaller than a 3.4 or so with a 6 rib is a losing battle. |
02-02-2017, 09:27 AM | #88 |
OEM? Whats that?
I have no idea what u just said haha
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam. Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s Build and mods done by R&D Motorsports in Baton Rouge Tune/Dyno done by ,,Engine Power Systems in Baton Rouge |
02-02-2017, 12:45 PM | #89 | |
Drives: 2011 rjt Camaro SS Join Date: Sep 2016
02-28-2017, 10:54 AM | #90 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
I thought something was off with my tune, so I got a 2nd opinion. 'Turns out the tune is fine, but even with a 3.4" griptec pulley and super-tensioner (already have OD rears, BTW), I get massive and instant belt slip (~4 psi drop) above 6K RPMs. They recommended going to a 15% overdrive balancer and stock 3.8" front pulley, saying that would put me at about the same boost without the slip. I haven't been able to find a 15% OD balancer for my setup though. Thoughts?
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
02-28-2017, 11:00 AM | #91 |
Much larger than the IW or ATI balancer would not leave enough room between the water pump pulley and balancer for the belt. That is likely why the IW 10% is actually 8%. Also why we generally run OD cogs and 10 ribs whenever we can.
03-01-2017, 07:47 AM | #92 |
"Black Ace"
Thanks. The 2nd tuner metioned something like that. I suppose that could be why his partner never got back to me about finding a larger one, even though he swore one existed. I was really hoping to avoid the extra cost of an 8 or 10-rib setup (let alone a twin pump fuel system), but it looks like I don't have much of a choice (?). Which setup do you run, BTW?
03-01-2017, 06:37 PM | #93 |
You can get an OD 8 rib and try to run that with 6 ribs. I have been running 10 ribs since we developed our kit. The other issue with 6 ribs other than belt wrap with a small pulley is belt stretch. The 6 rib belts stretch under load between the balancer and blower pulley, so it lifts up over the blower pulley and lets too much air underneath so it slips.
03-02-2017, 02:23 PM | #94 | |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
03-02-2017, 03:52 PM | #95 |
Post #51 shows the alternate belt routing that helps a lot with the belt wrap. That is the prototype I made to move the idler without replacing the whole bearing support bracket. In that picture, that is an 8 rib belt and I got 16 psi on my 416 with a 4* overlap cam. We are doing the same thing with our whipple 10 rib set.
03-02-2017, 04:43 PM | #96 | |
03-02-2017, 05:18 PM | #97 |
Still ironing out the details, but looks like we will be able to use a core snout, then machine them to accept our ramp securely. This should reduce cost significantly, the design is done, just have to get some mill time freed up to make a couple test pieces, I already have a few core snouts. Then dyno testing.
03-02-2017, 07:32 PM | #98 | |
Drives: Moneypit Join Date: Nov 2013
Thread Tools | |
