![]() Drives: 2013 GAZ 2SS/RS Join Date: Feb 2012
2013 2SS/RS Wiring Diagrams, Backup Camera Wiring?
I'm looking for a wiring diagram, specifically which connector and wire color is the video output of the backup camera to the mylink radio/screen on the 2013 2SS/RS.
I'm upgrading from the Mylink NAV, and want to connect the stock backup camera to the new screen. Thanks, Robert
If you see it, get it, for tomorrow it may be gone!
Anyone know which wire is the camera signal going to the radio?
I'm installing my home made NAV Radio tomorrow, and would hate to cut out the stock camera, but will have no choice as I will be using an aftermarket camera if I can't figure out which wire is the stock camera video signal. Any help is appreciated. -Robert
Another member, StealthZL1 advised that the Metra BACKUPCAM2 connector will allow me to retain the factory camera.
Thanks StealthZL1
![]() Drives: 2013 Camaro 2SS Join Date: Nov 2012
I found a pretty good photo of the connector itself so if you wanted to splice in to your factory one , you can but it looks like since you already spent some money on your setup already, what's a few dollars more on the backup-2 harness to keep you from cutting into your factory wiring.
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Its pin #5 and 15
#6 |
Thanks guys, I could not find one of those connectors at any of my local car stereo shops, or Fry's this morning, and don't want to wait another week to mail order one, so splice it is.
You are a lifesaver 2SSRS!
#7 |
I used a right angle 2 pin dupont header, like found on motherboards for reset, HDD LED, etc. The pin spacing was perfect. My 8" screen auto switches upon going into reverse, and factory backup cam works perfectly, although no line in the center of the screen now.
Pin 5 was Video + and pin 15 was Video -.
#8 |
Thanks
Thanks i finally pulled the plug a year later to install a new head unit after the free sirus satellite subscription expired
#9 |
![]() Drives: 2015 Convertible Camaro 1LT Join Date: Jul 2016
Do we have a reverse signal detection wire in Mylink?
Thread Tools | |
