10-16-2013, 11:49 AM | #1 |
synergy2011
Zl1 pedal covers??
Need help Install new zl1 brake and clutch pedal cover tried bake and heat and no luck very aggravated
2011 synergy green ss/rs,rally stripes
10-17-2013, 12:34 AM | #2 |
Drives: 2013 Camaro ZL1 (IOM) Join Date: Oct 2012
Try soaking the covers in hot soapy water before trying to install them.
10-21-2013, 07:36 PM | #3 |
Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
I used a very small, thin screwdriver and WD-40. Sprayed the rubber on the inside and coated screwdriver. Work 3 sides in (bottom and sides) and then work the tiny screwdriver in the top corners to pry the rubber end on the top up and over and work it to the middle...doing a little kind of crow bar action while pushing up at the bottom of the pedal to let it have a little "give".
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
11-02-2013, 01:07 AM | #4 |
Drives: Camaro SS Join Date: Dec 2012
I tried several suggestions and I found that the brake (and clutch) covers are rubber with a metal plate over them that is glued. I simply dipped them in hot water, seperated the rubber cover from the metal cover, installed the rubber cover in 10 seconds and reglued the metal cover. It was super simple.
04-03-2014, 09:41 PM | #5 | |
04-04-2014, 02:11 AM | #6 |
04-04-2014, 08:40 AM | #7 |
Cool, thanks!
Anyone who is getting these pedals, separate the aluminum cover from the rubber pad by heating with hair dryer - then slowly remove aluminum from rubber - put rubber pad on pedal - then re-glue aluminum on installed rubber pad. 100% easier!! Using this method makes the gas pedal the most difficult of the 3 pedals by far.
08-14-2023, 07:51 PM | #8 |
Drives: 2010 Camaro 2SS Join Date: Jul 2011
Going to try separating the metal from the rubber. Cause these pedal pads are whooping my ass. Tried lube on the inside and small flat head and no luck. Ugh
2010 Camaro 2SS. Triple black and slow at the moment. Lowered with a 1LE 3.91 gears, brake cooling ducts. It’s a canyon carver.
04-11-2024, 12:04 PM | #9 |
Drives: Camaro 2SS/RS Join Date: Apr 2022
ZL1 Pedals
Thread Tools | |
