12-11-2014, 03:33 PM | #1 |
Drives: Camaro SS Join Date: Dec 2012
Trailing Arms / Toe Links Upgrade
Looking to do a little suspension upgrade and would like to start with some trailing arms and toe links. Looking at a few options but my question is how difficult are they to install and can they be done on stands in the garage? Any DIY guides to help out?
12-11-2014, 04:35 PM | #2 |
I don't know the difficulty of installing them as I paid to have mines installed . But I did watched one of my boys installed his in front of his house on jack stands. I tell ya one thing it will be a very tight squeeze working like that GL !!
The DREAM is free... It's the HUSTLE that is sold seperately
12-12-2014, 09:39 AM | #3 |
Drives: 2010 Camaro 2SS/RS Supercharged Join Date: Nov 2013
Doing mine tonight. I might make a video since I couldn't find any on youtube. "BMR"
2010 2SS/RS Magnuson Supercharged, Headers, Corsa Exhaust, CAI
12-12-2014, 01:17 PM | #4 |
BMR provides good instructions. It's pretty strait forward, but you will have to drop the cradle a little bit to get the drivers side inner toe link bolt out. The outer trailing arm bushing in the knuckle can be a PITA as well, but it's definitely all doable on jack stands if you are mechanically inclined.
Best regards, Tyler 888-308-6007 |
12-17-2014, 04:28 PM | #5 |
Trentin24
What trailing arms are you going with? I went with BMR on my '10 V6. But not sure which ones for my '11 SS. I would like to stick with BMR though.
12-17-2014, 08:02 PM | #6 |
I'm picking them up tomorrow when I swing by BMR. I ended up placing an order for:
DTB004 Tunnel Brace SFC015 Subframe Conector TR002 Toe Links TCA026 Trailing Arms |
12-17-2014, 08:47 PM | #7 |
The ZL1 toe links are as good as any aftermarket parts out there.
Just ask Pete.
12-17-2014, 11:51 PM | #8 |
whippled 5th gen
you will love how good it hooks once finished, I added the bmr toe rods, trailing arms, upper control arm bushings, and full cradle bushings. then just recently added the sb 039 rear sway bar, helped me out a lot but to me the biggest difference were the toe rods and trailing arms. I also have their tunnel brace and subframes. just make sure you get their trailing arm bushings
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
12-18-2014, 07:30 AM | #9 |
12-18-2014, 07:35 AM | #10 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
12-18-2014, 08:43 AM | #11 |
12-18-2014, 08:51 AM | #12 |
It was still funny
12-18-2014, 09:30 AM | #13 | |
Drives: Race Car Join Date: Sep 2009
12-18-2014, 01:29 PM | #14 | |
Got em today and the BMR stuff is top quality and make the stock stuff look like aluminum foil. Can't wait to get em installed. Best customer service and got a tour of the plant. Can't say enough on how awesome they are.
Thread Tools | |
