Old 02-25-2015, 06:23 PM   #1
NJScorpio
NJScorpio's Avatar
Drives: 2018 Camaro 1LT Hyper Blue Metallic
Have I been keeping my tire pressure too low?
Off the top of my head, cold they are all 32 or 33 psi. They are 18", fwiw.
I may be 100% wrong.
NJScorpio is offline   Reply With Quote
Old 02-25-2015, 06:25 PM   #2
itsnotacrisis
Drives: '13 2LT RS,Blue Ray Metallic/mojave
Stock wheels and tires?
If so, your recommended tire psi is on a sticker on the drivers side door jamb.
itsnotacrisis is offline   Reply With Quote
Old 02-25-2015, 06:28 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
This. Look on you door jam for the correct COLD PSI.
FSP tuned: 377/389
Old 02-25-2015, 06:37 PM   #4
Scott@Bjorn3D
36 cold pounds.
Scott@Bjorn3D is offline   Reply With Quote
Old 02-25-2015, 06:37 PM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Originally Posted by Scott@Bjorn3D View Post
36 cold pounds.
That's is for 20's. Not sure it's the same for the 18's.
FSP tuned: 377/389
Old 02-26-2015, 12:13 AM   #6
enzia35
Drives: '16 Garnet Red 1SS
No poll? Disappointed. 1 starred.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 02-26-2015, 09:18 AM   #7
NJScorpio
NJScorpio's Avatar
lol, it would actually be suited for a poll, but I've had a conflict with a moderator here (because of my polls as well as off topic posting), so I'm trying to be respectful.
Old 02-26-2015, 09:57 AM   #8
enzia35
The pressure should be about 36 also for the 18" stock wheels.
'16 Camaro 1SS
'18 Miata GT
Old 02-27-2015, 04:08 AM   #9
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
typically if no placard they should be around 34-36 psi. that the rule of thumb for all passenger tires.
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 02-27-2015, 04:37 AM   #10
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
generally 36, lower pressure will give you better traction on ice(more tread contact), not snow.
Old 02-27-2015, 02:34 PM   #11
EARL99208
EARL99208's Avatar
Drives: ZL1 6sp.
I'm on 20's and I keep mine all as close as possible to the 36lb mark.
EARL99208 is offline   Reply With Quote
Old 02-27-2015, 03:03 PM   #12
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
You don't find them too heavy there?
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 02-27-2015, 03:06 PM   #13
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
i keep mine on 29 or 30. helps with traction in the winter lol
Tmick5jr is offline   Reply With Quote
Old 02-27-2015, 05:36 PM   #14
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I keep mine at 31-32 cold, they go up to 34-36 when they warm up. I have the Goodyear supercars and they seem to be very sensitive to heat.
Jenner is offline   Reply With Quote
