Old 05-28-2015, 04:30 PM   #1
chevyboy01438
chevyboy01438's Avatar
Drives: 2010 Camaro 1SS
Caliper painting?
I've seen several posts about people using VHT paint on there calipers. My question is, do you have to bake them like the directions say?
Off the Vehicle
Paint must be completely dry before curing
Heat to 250°F (121°C) for 30 minutes
Cool for 30 minutes
Heat to 400°F (204°C) for 30 minutes
Cool for 30 minutes
Heat to 650°F (343°C ) for 30 minutes
I haven't seen anything about people doing this. Also do you use the clear coat as well?
Thank you for any Input
Mod List: Perma-Grin, Darkened tail lights, ZL1 3rd break light, JW Motorsports LED side markers, American Authorities Window Louver, American Authority ZL1 bumper,
11/30/17 | Club F1FTY
chevyboy01438 is offline   Reply With Quote
Old 05-28-2015, 04:51 PM   #2
Hetfield03
Hetfield03's Avatar
Drives: 2010 2LT/RS Black/IOM
Baking? Why is this necessary? I'm getting a g2 kit. No priming or clearcoat necessary.
Hetfield03 is offline   Reply With Quote
Old 05-28-2015, 04:56 PM   #3
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Just use G2
Old 05-28-2015, 04:58 PM   #4
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
G2 is better, and it doesn't fade away the color!
hzisfrom1994 is offline   Reply With Quote
Old 05-28-2015, 05:19 PM   #5
GraySS2011
Drives: 2011 Cyber Gray 2SS 6 speed
I used the G2 kit and was very happy with the results. You have to put your car up on jack stands and clean the brake dust completely out . Once you open the can and mix in the activator, you have 4 to 6 hours to use t. It hardens like a piece of plastic around the caliper and remains super glossary. The paint is self leveling and shows no brush marks. Painted without removing the calipers from the rotor.
Before high temp decal
GraySS2011 is offline   Reply With Quote
Old 05-28-2015, 05:25 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I did the G2 kit.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-28-2015, 05:27 PM   #7
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
GraySS - How hard is it to apply? Did you remove the Caliper completely or can you tape off the area you don't want to paint and paint it, as it sits on the rotor? I am weighing whether to paint using the g2 or have them powdercoated.
graf101 is offline   Reply With Quote
Old 05-28-2015, 05:47 PM   #8
Mike_G
Drives: 2010 2SS/RS
I used the VHT and the color has held up great for the last year. I did use clear. I sprayed 3-4 coats color, applied the decals then 3 coats clear. Calipers were sanded down and degreaed well before painting.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 05-28-2015, 06:20 PM   #9
chevyboy01438
The baking is what i read off the can is why i asked. But if everyone is using the G2 kit then i will use that.
Old 05-28-2015, 06:46 PM   #10
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
G2 is more expensive and you have to use a paintbrush. Whatever you use, get caliper clear coat spray a few layers, it will look way better it will look powdercoated
Homeless Man is offline   Reply With Quote
Old 05-28-2015, 06:49 PM   #11
Ryanbabz71
Ryanbabz71's Avatar
You can leave them on. Brushing the paint on isn't difficult at all. I did 3 coats on all 4 calipers. 1 kit was plenty to do this. I added been I decals and clear coated
Ryan
Ryan
Old 05-28-2015, 06:55 PM   #12
bluebonn
Texas
bluebonn's Avatar
Drives: 2015 2SS Red Hot LS3
I used the G2 kit and brushed mine Can't beat the price and look for under $30
bluebonn is offline   Reply With Quote
Old 05-28-2015, 07:03 PM   #13
chevyboy01438
How long do you wait between coats? Also i have the chevrolet stickers, is it proper to put the brembo decal as well? I really like the gloss of those calipers!
Old 05-28-2015, 07:14 PM   #14
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
I used 500 degree engine enamel from Advance Auto. A can of orange and clear coat. Bought the hi temp decals online. And applied the clear coat on top of the decals. Engine enamel wears like iron and nice smooth finish. Did mine over a year ago and still looks like when I first did it. Do yourself a favor take the time to pull the calipers and clean it and paint it removed from the car. You should do the disks as well because they rust if you don't.
[/URL]
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
