![]() Drives: 2014 Chevy Camaro ZL1 Join Date: Sep 2014
Heads For Turbos
Hey turbo zl1 guy. What are you guys running heads, springs etc?
![]() ![]() Drives: 2013 ZL1 Join Date: Jan 2015
I'm using stock heads with a BTR stage 2 cam and comp springs. It's enough to make over 800 with an auto. Not sure you need better heads unless you want to go crazy. Mast makes a great head for either 4 or six bolt heads.
2013 A6 ZL1
Who sells the Mast? I saw Texas speed sells a set but not sure what would be ok to run
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Stock heads would be fine for ~1000rwhp. If you are going past that just about any solid 6 bolt head will work. PRC, Mast, All pro, etc.
Nick
Corvette Z06 -1200ish rwhp |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ( . )( . ) Join Date: Feb 2010
I was expecting something very different from the tittle.....
#6 |
Lots of heads would be ok to run. Target rpm range, cam specs, boost levels, fuel type, intended use of car, etc all play a part to selecting heads. The biggest is the cam/head combo creating enough torque for our cars. With a 3300lbs vette you may want lots of high rpm hp, our camaros need more torque.
2013 A6 ZL1
#7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Unreal is on track. When the horsepower gets over 1000 it gets very difficult to keep the head bolted down tight enough to keep the gasket integrity. I think you can get away with a lot in drag racing because at this power level you only have 9 or 10 seconds of throttle but if you try to run other longer events you need to invest in a 6 bolt head.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
Thread Tools | |
