09-02-2016, 10:17 AM | #1 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Oil weight and type for turbo setups
Trying tp see if i need to be using synthetic or blend or conventional oil, then 2nd what weight of oil, im not looking for brand specifics as to not start a war on ppl naming the best or the highest sht when really not need for car to function as a daily driver not race car or track or drag. Just wanna make sure the stuff im using now isnt to thin when heated in this texas heat 90 to 105 weather. Im currently using pennzoil synthetic from natural gas, 5w30
09-02-2016, 10:23 AM | #2 |
Drives: 2010 Camaro SS AT6 (L99) Join Date: May 2016
I would use a synthetic that has a HTHS rating of at least 3.5 which would be most quality 0w-40 or 5w-40 like M1, Amsoil, or Castrol "euro formulation" oils.
Mike |
09-02-2016, 10:34 AM | #3 |
Hths?
09-02-2016, 10:38 AM | #4 |
high temperature high shear. Your 30 oils cant perform as well at higher temperatures. You also dont want too thick of an oil and particularly not too thick of one at startup (such as a 20w-50). You just end up losing a bit of power, losing a bit of fuel economy, and putting increased stress on the engine with too thick of an oil. A good compromise then is picking a 0w-40 that has very good high temp performance but a great cold viscosity as well. The euro formulation oils in the 0w-40 range possess these qualities as they were developed for very extended drain intervals and often in factor turbo or supercharged engines (bmw, audi, mb).
Mike |
09-02-2016, 11:03 AM | #5 |
Awesome thxs for the info, does autozone or walmart sell 0w40 in synthetic
09-02-2016, 11:07 AM | #6 |
Too much is never enough!
I run Joe Gibbs DT40. But I run different tolerances than a stock motor. Before I built the motor, I ran 5w-30. Honestly, I would call someone like the people at Joe gibbs, tell them where you are, and what you have, and let them recommend an oil, instead of us professionals telling you...
09-02-2016, 11:24 AM | #7 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Marketing has really tainted the oil arena. Keeping relatively clean oil in the car is best - think of it as a cheap insurance policy, change the oil or change the motor. To your question: what does the turbo vendor/install/tuner suggest? AGP suggested 20w50 in the hot months and 10w40 wintertime. I've even tried the Mobil 1 5w40 turbo diesel in the summer and quite honestly, it has all worked fine. And, I run the crap out of my car with drag racing, autocross and road course. If you're paranoid, you can always send a sample off to Blackstone for analysis. I did after 5,000miles of beating on the car. The answer was oil looked great with less than usual wear products. They also said the recommended average miles for my type of motor was to change the oil every 3,700miles. So, end of story, don't fall for the brand marketing pitch - just keep clean oil in the car. Any SAE will do. Synthetic does stay cleaner longer.
> 2021 Camaro ZL1 1LE A10 - power upgrades in the initial design phase > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
09-02-2016, 11:27 AM | #8 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
I run Brad Penn in mid May I put 20w50 for summer , and in October change to 10w40 for winter---stock motor(AGP recommended)! When I build motor I would know exact bearing clearance and go by that
AGP TT 807whp 811wtq 13.46psi E85+methanol
09-02-2016, 11:42 AM | #9 |
I appreciate the info guys i really do
09-02-2016, 11:43 AM | #10 |
Lmao texas dont have no winters or houston dont lol
09-02-2016, 11:47 AM | #11 |
Bearing clearance dictates oil. Turbo does not.
Nick
Corvette Z06 -1200ish rwhp |
09-02-2016, 11:50 AM | #12 |
Atock motor
09-02-2016, 11:54 AM | #13 |
Stock motor with custom grind cam
09-02-2016, 01:57 PM | #14 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I use Rotella t6 5w40. cheaper alternative to some of the other oils. ran it in my twin turbo sbc car as well and will be running it in my turbo 5.3 as well.
Thread Tools | |
