Old 06-28-2017, 08:57 AM   #1
RubberChicken
RubberChicken's Avatar
Drives: 2011 IBM 1LT w white Rally Stripes
Wind noise coming through closed passenger side window
Good morning all! Does anyone else have the problem of wind noise making a sharp shrieking sound coming from the passenger side window when either it's particularly windy or going a decent rate of speed? I checked the door and there doesn't appear to be anything wrong with the seal. When it's happening, if I crack the window just an inch or so the noise will go away.
RubberChicken is offline   Reply With Quote
Old 06-28-2017, 09:14 AM   #2
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
here in windy OK, yes! I noticed it on my older Firebirds as well back in the day. anything without a full window frame, that damn okie wind makes noise even sitting still!
DvKillar is offline   Reply With Quote
Old 06-28-2017, 10:34 AM   #3
WoodBoss
"Old School"
Drives: 2010 2SS L99
Is the window indexing properly? Does it move down a little when you open it and then when you close it goes back up?
WoodBoss is offline   Reply With Quote
Old 06-28-2017, 10:38 AM   #4
RubberChicken
Yes, indexing works as expected. Great question!
Old 06-28-2017, 10:50 AM   #5
WoodBoss
"Old School"
Does it seem like it is compressing the seal evenly? Maybe clean the window and wipe a little Armorall on the seal.
Old 06-28-2017, 11:12 AM   #6
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
I would use Vinylex on rubber in lieu of Armorall.
Junior is offline   Reply With Quote
Old 06-28-2017, 02:29 PM   #7
SquawkVFR
Drives: 2010 Camaro
This could be a sign your car door is a bit off alignment. Don't panic. It happens. Get to a dealership asap, it'll take them about 5 minutes and probably won't even charge you.
SquawkVFR is offline   Reply With Quote
Old 06-28-2017, 03:00 PM   #8
RubberChicken
Good to know!
Thanks for the replies, all!
Old 06-28-2017, 05:27 PM   #9
Mac Arnold
Drives: 2011 Camaro 2SS/RS
This is great information! I have noticed it as well, but on the drivers side. I am going to clean the seals on both sides this weekend and see what happens.
Mac Arnold is offline   Reply With Quote
Old 06-30-2017, 01:44 PM   #10
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I noticed my passenger window making wind noise. When I looked closer it looked like the front portion of the glass was lower than the rear half, so much so that the glass wasn't entering the rubber seal completely. I tried lifting the front edge but no dice. Had to remove the door panel, locate the point where the glass mounted to the hardware. Found I could loosen a bolt and pry the bracket up slightly, re-tighten the bolt, and tested the window. While I couldn't move the front edge bracket up much, it was enough to make a difference and now the glass fully enters the rubber seal. No more wind noise. The passenger door had been sideswiped and IMHO the shlock body shop didn't do a good job putting in a new door. Well, they said it was a new door, but judging from other corner-cutting repairs they did, I probably have 10 lbs of bondo on that door.
Meh
My 5th is offline   Reply With Quote
Old 06-30-2017, 02:11 PM   #11
DvKillar
DvKillar's Avatar
You serious, Clark?
because my door is not aligned. glass seals, but it is higher on the inside than the dash. heard it was common, but wasn't sure about being covered under remaining warranty.
Old 06-30-2017, 02:20 PM   #12
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Originally Posted by DvKillar View Post
You serious, Clark?
Doors are aligned to panel gap specs nothing to do with the window. If your door gaps look the same down the front and back its not the problem. Like others
have said ..it could be the window itself or the rubber seal having an issue.
rontammy0 is offline   Reply With Quote
Old 06-30-2017, 02:23 PM   #13
alrock
alrock's Avatar
Drives: 2015 Camaro Convertible 2SS RS
I have this on my driver's door. Dealership called it a design feature. Seriously. ****tards.
alrock is offline   Reply With Quote
