01-07-2019, 09:55 PM | #1 |
Drives: 2013 1LE RS 1SS Join Date: Apr 2009
best head combo with stock bottom end
so many options but im debating using cathedral port heads like trickflows to have more piston to valve clearance
whats your suggestions also I will be milling them to up the compression as much as possible |
01-07-2019, 10:06 PM | #2 |
Drives: 2015 1LE Join Date: Oct 2015
Use an aftermarket head with 11 or 12 degree valve angle. I would stay with the rectangular port LS3, what kind of cam are you thinking of?
Trick flow 255 is a good head, most aftermarkets are good but I would suggest inspecting the valve jobs before putting them on.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
01-07-2019, 10:30 PM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
Custom is kewl for valve clearance and big torque with better velocity in thr port design. Say like Mast motorsport, PRC, AFR, etc.
Ported stockers are really good; FED, TEA, GPI are smong my favorite shop to have it done. Going cathedral would negate the benefits of running a bigger cam. Its a big no imo. So many option for ls3 manifolds and huge big flow numbers make power...youre going in the wrong direction for sure.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
01-07-2019, 11:36 PM | #4 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
01-07-2019, 11:47 PM | #5 |
Drives: 14 and 15 SS's Join Date: Feb 2018
I just bought some SPS haymaker heads. Not a lot of info on them but they look promising. I've called Gavin several times with questions and he has been awesome to deal with. I bought them from Thompson Motorsports. I believe Gavin sells them direct or through a vendor. Thompson put them into a package for me.
They are 11 degree valve angle, .750" deck, 4 or 6 bolt and some really good claimed flow numbers. They look like a sweet head for a 4" bore https://www.spsheads.com/shop
Bolt-ons!
01-07-2019, 11:57 PM | #6 | |
o am trying to get more power in the middle and up top without spinning it over like 6800-7000 also would like to max out compression I will be running e85 so ill have enough octane have not put much thought into intakes |
01-08-2019, 12:01 AM | #7 | |
01-08-2019, 06:04 AM | #8 |
There are many companies like GPI, Mast and Texas Speed that make a "small bore" LS7 style head that you can use on a LS3 engine. So you get the raised runner, shallow valve angle and LS7 valve train on a LS3. You have to use an LS7 intake manifold with these heads too.
The great thing about picking heads is there are not really any bad options. Mast Motorsports makes really nice heads but they are expensive.
01-08-2019, 07:15 AM | #9 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
I'd go with an Edelbrock setup.
01-08-2019, 07:40 AM | #10 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
WCCH Brodix BR3 (the small bore LS7 head for and LS3) with an LS7 intake and a healthy cam. You would need rear gears and a torque convertor if auto.
When I forge mine for FI will definately be moving to LS7 type set up...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
01-08-2019, 08:42 AM | #11 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
if you're at stock cubic inch and are not going to spin it over 6800, the stock LS3 intake will be fine. Its almost unbeatable under 6800 rpms BUT, its gonna restrict the crap out of your heads. You will have spent the money just for the valve angles. to max out compression and power you will have to go with 11/12/13 degree valve heads in order to have the additional PTV clearance after milling them in order to run the btr stage 3 or "bigger" cam. As zz430 and a couple others have mentioned, there are many aftermarket head choices for LS3s. If you want to keep the power down low, go with the smaller runners like a TFS255 The bigger volume of the runners will make more power at higher rpms. Texas Speed PRC260, Mamo, GPI, AFR, MAST, Brodix, etc. etc. And yes, you will benefit from E85 once you get past 11:1 SCR My 2 cents, if you're gonna spend the money on some nice heads, spin that bitch. I've spun mine to 7200 and can testify that the motor wants to go more but the stock LS3 intake manifold is restricting the crap out of my of heads past 67ish and i know the motor can spin to 7500 easily
Bone Stock |
01-08-2019, 08:45 AM | #12 | |
The only reason i didnt go with the "mini 7s" (as dave at wcch dubs them) was because of the additional cost of the LS7 rockers and intake manifold added to the cost. But yes, LS7 top end on LS3 is a beautiful thing!!!!
Bone Stock |
01-08-2019, 09:32 AM | #13 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
WCCH BR7-3 or I personally went with the Air flow research 260cc mongoose heads with the upgraded exhaust valves..
01-08-2019, 09:37 AM | #14 | |
Thats the exact same setup i went with.......AND milled .030" FTW!
Bone Stock |
Thread Tools | |
