06-21-2019, 11:36 AM | #1 |
Drives: 2015 Camaro 2LT Join Date: Feb 2019
Exhaust suggestions?
I've done some reading and just wanted to confirm if these parts are what I needed for my 2015 LT to convert to quad tips.. Some of the questions I have
1. Any suggestions for an exhaust? I've seen most people use MRT V1 or V2, Corsa, Magnaflow. Does anyone have anything else I can look into so I can review my options some more. Leaning towards getting MRT V2 though. Anyone know where best to get this for a good price? 2. I'll probably get the 1LE diffuser, but would the ZL1 (22829478) fit without any issues? I've seen some say it wouldn't, some said it would. 3. If the parts down below are correct and I get a suggestion, how many inches in and out for the tips would you recommend? 1LE = 22829477 - https://www.gmpartsdirect.com/oem-pa...cover-22829477 Zl1 = 22829478 - https://www.gmpartsdirect.com/oem-pa...cover-22829478 Tips - http://tips.byethost4.com/dualindividual.html Last edited by hartleyrs02; 06-21-2019 at 12:18 PM. |
06-21-2019, 12:49 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
1. With whatever you get I'd say you should get the Magnaflow 11386 to replace the stock resonators and H pipe to get the tone deeper and keep the drone down.
2. Yes, both work. 3. 2.5" in 4" out. That's ZL1 or NPP exhaust sizes I believe.
06-21-2019, 01:38 PM | #3 |
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6 Join Date: Dec 2016
Pypes stainless cat back. x-pipe mid muf
love mine
CamaroLIFE
Thread Tools | |
