08-21-2019, 02:24 PM | #1 |
Semper Fi!
Drives: 2018 ZL1 Join Date: Jun 2018
How do you clean the debris off the Aux trans cooler?
Hope this is not a silly question, but does anyone have a simple way of removing the debris that is caught on the cooler that sits flat on the front end of grill?
Got some leaves and other stuff stuck in there and cant reach my hand in there to remove it. TIA |
08-21-2019, 02:31 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Shop vac with extension
08-21-2019, 02:45 PM | #3 |
Drives: 2019 Camaro ZL1 1LE Join Date: Jun 2019
08-21-2019, 03:46 PM | #4 |
Semper Fi!
Thanks! I have a hand held vac...maybe time to get a shop vac.
08-21-2019, 05:04 PM | #5 |
Drives: 2018 ZL-1 Join Date: Jan 2018
I'll do that too. That whole area has about 25 grasshoppers and other nasty dried bug carcasses in there.
08-21-2019, 05:17 PM | #6 |
There is another alternative. Poorboys bug squash, melts bugs but is not harmful to any of the metal or paint. Sprayed on liberally, really getting down into the vanes , wait a half hour, and then take a moderate water hose stream to it , being careful… Once it’s real clean, pull the rest of the stuff out with the shop vac thin nozzle.....go slow.
This usually occurs because you’ve taking a long trip. Around town it doesn’t seem to get clogged up. This is the reason the Novistretch bra is so good for long trips, as it protects all these radiators… |
08-21-2019, 06:36 PM | #7 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
+1 to the shop vac with the skinny upholstery attachment.
Whatever you do... do not spray a pressure washer into the grille area or you may flatten all the fins on the radiators. |
Thread Tools | |
