Old 11-27-2020, 03:57 PM   #1
Birddogg
Drives: 2006 Z51
Brand New Comp Cams LS7 front cover
This is a brand new cover that is for the LS7 or the RHS block.
I am selling because I was going to use this cover however my super charger made contact and it would not work on my RHS block.
This was only test fitted and never cranked down onto the block. It is new and unused.
Thanks. CAmaro5
Birddogg is offline   Reply With Quote
Old 11-27-2020, 09:47 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
How much an will it work on a LS3??
Orange Krush II
Old 01-01-2021, 11:35 AM   #3
Birddogg
Drives: 2006 Z51
This cover is for a LS7-LSx or a RHS motor only!
Old 01-01-2021, 05:19 PM   #4
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Pm sent
SIM GhostrdrZ is offline   Reply With Quote
Old 01-07-2021, 12:30 AM   #5
232_ray
Drives: 2013 ZL1 / 1969 Z/28 camaro
How much? This will fit a Chevrolet LS7 block??
232_ray is offline   Reply With Quote
Old 01-14-2021, 10:19 PM   #6
Birddogg
Drives: 2006 Z51
I sent you a PM
Old 02-01-2021, 01:31 PM   #7
Birddogg
Drives: 2006 Z51
This is still on the market
Old 02-02-2021, 01:14 AM   #8
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Dang it I just bought one
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 02-21-2021, 02:10 PM   #9
Birddogg
Drives: 2006 Z51
Bump up
Old 02-21-2021, 03:08 PM   #10
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
how much $$$$$$$$$$$$
Blownfogger540 is offline   Reply With Quote
Old 02-22-2021, 01:23 PM   #11
Birddogg
Drives: 2006 Z51
I can do 250.00 for it. I paid 300 for it from Speed Inc.
