05-03-2022, 08:31 AM | #1 |
Drives: 11 BLK 2SS/RS Join Date: Feb 2015
PCM-Electric mechanic needed in DFW
Anyone have a good mechanic in this area that they recommend. I have been chasing a gremlin causing a P0205 code that I believe is tied to a wiring issue between my fuel injector and the PCM. I have been jerked around by two mechanics now who said they would see my car and ghosted me.
"Cry 'Havoc!', and let slip the dogs of war"
05-03-2022, 12:43 PM | #2 |
Drives: Chevrolet Camaro SS Join Date: Jul 2021
I don't know about that item, specifically, but I've been pretty happy on other stuff with the guys at 21st Century Muscle Car in Addison.
05-12-2022, 12:41 PM | #3 | |
Drives: 2012 Camaro 2SS Join Date: Aug 2017
How did you make out?
Texas Speed Long tubes, highflow cats, Borla Cat back S-Type, Spectre Cold Air Intake, HP tuner tune
03-19-2023, 10:05 AM | #4 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
Hey I know it’s a old post, but I’ve got 30yrs experience and your B pcm is commanding the injector to open but not get back signal that the injector opened..shouldn’t be a big deal, it’s a ground or a driver I’d imagine..unless it’s something weird
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
03-19-2023, 12:54 PM | #5 |
Listen to see if injector is working by using a long extension putting it up to your ear..no clicking then Worst case just bypass the whole harness injector ground. it’s just one wire ,then check the voltage at the box and the injector ,next get a known good part install it in harness listen to it if the other one wasn’t clicking ..if it runs fine with bypass harness then just go inch by inch on older harness untill you find short break etc..
Thread Tools | |
