03-02-2023, 10:33 AM | #1 |
Drives: 2014 Camaro SS Join Date: Feb 2022
Which FMIC with D1SC?
So I'm at the point I need to upgrade the IC on my setup. Making 7xx whp off a d1sc blower @ 13 psi and IAT's are through the roof. I've narrowed it down to a few options, trying to decide between them. Car is a street car with A/C so it needs to still get enough airflow to the radiator/condenser for that. I will be swapping to the RSM tubular crash bar so clearance shouldn't be an issue with any of them.
AGP Race Intercooler On3 6" Intercooler Treadstone 1045 Treadstone 1245 I've read that my current piping will mate up to the treadstone units without modification, so right now I'm leaning that direction, but I can definitely be swayed to the others. |
03-02-2023, 08:09 PM | #2 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Hell I use the Stage II race intercooler that came with a D1 system, I sold the D1 before install and bought a F1-A with less than 50 miles on it. I now max that out on a 7.0L w/LS3 top end, factory bumper brace, radiator, and A/C... zero issues, but I run pump E-85 with a flex fuel sensor and a Squash dual pump setup on a hobbs switch. I wouldn't rule out flex fuel, or even meth injection to help with the intake temps.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
03-03-2023, 09:13 AM | #3 | |
03-03-2023, 09:45 AM | #4 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Where is your MAF (temp sensor) located in your setup?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-03-2023, 09:57 AM | #5 |
I'm not sure offhand, but I don't think it makes a difference at this point. If it was in a bad location I'm confident the tuner would have said so. The car is definitely down on power from high temps, and my research has determined without a doubt that the current IC I have is too small for my setup. Procharger themselves state it is only enough for completely stock/mildly modified applications. My car is cammed/FBO/e85 making ~2× the boost that this IC is designed for with the kit.
03-03-2023, 10:31 AM | #6 | |
Something I found very interesting is that when I moved/swapped my location/to an aftermarket IAT sensor from the usual MAF location to just behind the throttle body, and upgraded to a fast acting RIFE temperature sensor, my IAT's dropped significantly. I believe, more or less, that the new sensor is magnitudes faster reacting to the temperature changes (not allowing for heat soaking the sensor). For instance, when at an idle (throttle plates closed), the IAT's increased as it has low airflow (e.g, from a little bebop around town, IATs at 136F start of just sitting there after the cruise, rising to 158F before shutting off the motor after 3-4min of idling) . At cruise, they were lower but still at a relatively moderate level (throttle plates nearly closed) (while cruising that day the IATs hung around 113F). But, when I laid into the pedal, the IAT's dropped quickly as more air flowed across the sensor, and in boost (depending on how much since I'm turbo), the temperatures started significantly lower then slowly climbed (dropped quickly to 91F then slowly rose to 94F with 13psi boost from 40mph to 97mph), but never to the point when the OEM MAF sensor displayed. Months later, on top of moving the sensor, I did add water/meth injection and it clearly shows how that has affected (kept my high boost level temperatures very much controlled). I'm just bringing this to the table as I think moving the sensor and changing to a quick reacting one provides way better IAT monitoring and controls. I'm a true believer for placing a dedicated IAT sensor where it should be, and the right sensor. BTW, I have a heavy cast aluminum intake manifold which is a super heat soaking bastard, but the sensor appears to only be interesting in measuring the airflow passing it rather than allowing the sensor mount soak up the heat energy.
03-03-2023, 10:57 AM | #7 | |
03-03-2023, 08:24 PM | #8 | |
Drives: 1991 Camaro Join Date: Apr 2012
2011 SS Twin Turbo
Forged LS9/6L90E Runs 9's |
03-04-2023, 01:37 AM | #9 |
Yes, RIFE provides that data.
03-06-2023, 06:32 AM | #10 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I know I sound like a broken record and the worlds biggest salesman for ESS, but show me another setup making 1100+whp without meth with IAT's peaking at 98 on the dyno. Their intercooler is a beast and fits behind the stock crash bar. Of course the size of the blower and its effeciency plays into it as well.
During a private track rental I did 4 hotlaps and IATs climbed to 140. That's the hottest I have ever seen them.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-10-2023, 06:59 PM | #11 | |
Thread Tools | |
