04-05-2024, 05:17 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Broken Rocker arm
So went into the shop to get a header leak fixed and they found this bc of the ticking. I thought it was from the leak but looks to be a broken rocker arm smh. Been driving the car like this for like 3 weeks and oil pressure is normal and normal driving behavior. My question is what’s next? Oil change and replace rocker, spring, pushrod? Or should I have a engine tear down? I have a built dart engine and the rockers are from the old motor.
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
04-05-2024, 06:24 PM | #2 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Just my opinion, but I wouldn't tear down for that.
I would pull the spring, make sure it's not damaged and no debris inside of it. Check the pushrod is clean and straight. Make sure no debris is still sitting in the top of the head. Change the oil and filter of course!
04-05-2024, 07:02 PM | #3 | |
04-05-2024, 09:00 PM | #4 |
Drives: ABM #93 Join Date: Oct 2018
I would do a trunnion upgrade while your in there, especially if you are on a built 427.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
04-05-2024, 10:43 PM | #5 |
Did those trunnions have the needle bearings? If so they're probably in the pan and pickup screen.
04-06-2024, 10:17 PM | #6 | |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
You should get the front of the car as high as possible , drain the oil, and flush out the oil pan vigorously with about 5 gallons of diesel to flush out all the needle bearings yo can. Then look in the drain hole with a bore scope. There pretty cheap. Maybe fish around with a magnet too. You gotta get those pieces out of there. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-07-2024, 08:55 AM | #7 |
Drives: 2012 camaro ss Join Date: Sep 2018
I thought the whole point of doing trunnions was to get rid of the needle bearings? I know mine dont have any.
GPI Powered
04-07-2024, 10:05 AM | #8 | |
My trunnion upgrade still uses bearings over bushings. (BTR v2) The bearings weren't really the problem with the stock trunnions, it was the end caps. Higher lifting cams would make the end caps rotate more than intended and they would come out spilling the bearings in the process. BTR's use basically a washer with a circlip on each end to prevent it from coming off. So far mine have been on 15k miles without issue. |
04-07-2024, 05:11 PM | #9 | |
04-07-2024, 06:15 PM | #10 | |
GPI Powered
04-07-2024, 06:26 PM | #11 |
If I'm looking right, from the original picture of the OP, it looks like the intake rocker. If I had to let one go, that would be the one I would want. If the exhaust had let go and the intake continued to operate, things might have got interesting.
As a side note, it does look like the trunnions are upgraded now that my old eyes look closer. Last edited by FasNuf; 04-07-2024 at 06:40 PM. |
04-08-2024, 02:20 PM | #12 | |
04-08-2024, 07:22 PM | #13 | |
Thread Tools | |
