#141 | |
![]() Drives: '17 Zl1, '16 Viper ACR, '15 CLA 45 Join Date: Nov 2014
I was at the trackdaze event in my viper. Went back for the club event to test out the z/28, because i didnt want to wait till spring.
Ran a 2:50 in the viper and a 2:57 in the Z. Def a few more seconds left in the Z. Ive got countless hrs in the viper, and the z was my first and only day in it, the high temp was 50, but grip was good. |
#142 |
![]() Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE Join Date: Apr 2011
Ran CoTA (Circuit of the Americas) and best time was 2:47 average for about 4 laps. Check out my CoTA album too. Unbelievable F1 runs this course in about 1:35 ...
If you ever get the chance to run on this track - DO IT !!! The 1LE is a great car! http://youtu.be/AiJ7mpfZLB4
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!! Last edited by mySSt; 12-13-2014 at 01:36 PM. |
#143 | ||
![]() ![]() ![]() Drives: 2022 SS 1LE Join Date: Jul 2013
My goal is to beat my Viper's 1:52.7 with my Camaro at Buttonwillow Raceway. The cars are surprisingly close. The all-stock 2013 Viper GTS's 1:52.7 was on fresh Hoosier A6s, and the Camaro's 1:53.9 was on old Hoosier R6s. I think with equivalent tires the cars would be dead even. My Camaro has a lot of mods including gobs of downforce, but I'm still shocked that it is in the same league as the 500 Lb lighter, more powerful Viper. Here's the Camaro's 1:53.9. For more info on the Buttonwillow weekend, see my sig.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
#144 | |
...and here's the Viper's 1:52.9
If you're curious, here's the thread on the Viper: http://driveviper.com/forums/threads...-Personal-Best
#145 |
Did you get your AIM from Peter Krause? I was at his shop and he said he sent one out to a genV in cali.
#146 | |
The Camaro uses the same SmartyCam HD but has a more extensive system to monitor engine health as well as driver performance. I went with a local shop for this because I needed help with installation:
I still need to work out microphone placement, a lot of wind-buffeting noise at high speeds. You can hear this in the Camaro vid.
#147 | |
![]() Drives: 2014 Spring Edition SS Join Date: May 2014
Just a quick follow up on my rims in response to the post below. I took them to a local shop with a nice balancing machine and had them run a computer print-out on each of the rims. I sent that info to Jurrian at Mod Bargins who forwarded it on to Forgestar, and Forgestar has agreed to cut me a NEW set if rims and ship them to me! They have a theory as to what happened, and they want me to ship them back so they can run some tests. Forgestar is saying they definitely shouldn't have bent like they did and want to get to the bottom of exactly why they did bend.
I would be remiss if I didn't mention that Jurrian has been awesome to work with throughout this entire process and he's really helped me a lot. While I wish they never had bent in the first place, knowing Forgestar is going to make it right, and having Jurrian in my corner has made me a happy customer despite this little hiccup. All is good! Quote:
#148 | |
CamaroFans.com
Here's a nice Hennessy modified Z/28 running our track here in Houston.
#149 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 C7 Z51 Join Date: May 2012
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
#150 |
I sent you a PM about those OEM wheels. Not exactly sure on the theory they have yet. I'm sure Jurrian will let me know after they test them.
#151 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Here's one from the Ridge, very cool track in Shelton WA.
#152 |
The Ridge is also one of my favorites. Glad to see other Camaro owners also like it : )
Was it your first time? Looking forward to try my 1LE there when the season opens. I heard they are fixing a few turns (T13, etc.) at the time..
#153 | |
In The Circle
#154 |
