#169 | |
![]() Drives: silverado ss Join Date: Aug 2008
So let me get this straight; 1. a 2300 Magna Charger with a bypass for normality and "as needed" insane levels of power... 2. diverters with bypass for stealth quiet or dead waking noise and performance gain... 3. Black on Black - doesn't get much more evil than this color setup... This seems to be a Dr Jekyll and Mr Hyde story in the making. :seesaw: |
#170 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 LPE 650+ CTS-V Join Date: Oct 2008
Absolutely - I will be getting ahold of you when I get my car in!!
#171 |
![]() Drives: 2010 Camaro 2ss Join Date: Apr 2009
Will the diverters work with aftermarket Long tube headers?
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal |
#172 |
#173 |
![]() Drives: Rally Yellow 2SS 2010 Join Date: Mar 2009
Has the diverter caused any problems with the cars computer? The camaro that y'all installed, has he mentioned any problems with the car or computer? I understand the motor likes back pressure and with the diverter 100% open, does it or will it cause issues. One more question did you ever find info about the diverters possibly voiding the cars warranty?
#174 |
Anyone happen to know of some compatible LT 1 7/8" headers?
#175 |
![]() Drives: car Join Date: Mar 2009
wired into the power seat controller? I dont have power seats "LS". what do you recommend? what kind of results for a V6? IE: power and sound.
#176 | |
Also, When I get the car inspected, Of course I'll have the diverters 100% closed so the stock exhaust is used during the inspection. If they happened to see the diverters installed, how likely are they to flunk the car inspection because of the modification, even though the CATS were not touched?? Ready to order depending on the answers to these questions... ![]()
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!! ![]() |
#177 | |
![]() Drives: Hyundai Sonata Join Date: Feb 2009
No. There's no sensor in the exhaust that measures back pressure. If there was, adding a cat-back, or even an axle-back would throw codes because they, too, reduce back pressure. You may be getting these confused with long tube headers throwing codes. The only reason LT's can cause a code to be thrown (notice I said can, as in it's a possibility, not an absolute) is because they sometimes alter the placement of the O2 sensors, as well as EGT's, which can change readings outside of acceptable ranges. Since these cutouts don't alter the O2 placement or EGT's, and are behind the O2 sensors and catalytic convertors, they won't cause your check engine light to come on. |
#178 |
One more question about the electrical part of the installation. These actuators obviously need power to operate, so when you say you tied this unit into the power seat controller, what exactly was done and how? I mean are you guys talking about splicing eletrical wires or did you guys engineer a special power harness/plug that plugs in....where exactly? Or do you have to run a separate power wire to the battery like some amplifier installations? I'm really curious about this part of the installation. Everything else seems pretty sweet.
WOT is my happy place!! ![]() Last edited by Edrock; 05-23-2009 at 12:45 PM. |
#179 | ||
We have has several questions about the V6 sound and power gains, but we don't have any of that info, as we have yet to even see one or know 100% for sure that it will fit. If the "S" pipe is the same- which the cad files show they are, it will work. If someone has V6 exhaust pictures in the "S" pipe area that would be a great way to confirm the drawings. Thanks! |
#180 |
thanks for the info!!
#181 | |
#182 |
![]() Drives: 2010 Camaro 2SS VIN#11184 Join Date: May 2009
Really need to know the answer on the warranty. This is the last info needed before i make my choice on ordering or not.
Tags |
cutout, diverter, electric, exhaust, mufflers |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
Edmunds: 2010 Ford Mustang First Look | Scotsman | General Automotive + Other Cars Discussion | 32 | 11-23-2008 09:55 PM |
Automobilemag.com: 2010 Chevrolet Camaro - Q&A | Scotsman | 5th Gen Camaro SS LS LT General Discussions | 23 | 10-12-2008 12:13 AM |
Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 | AirGoya | Chevy Camaro vs... | 86 | 07-24-2008 11:20 AM |
Camaro (concept) Press Release!! | Pencil.Fight | 5th Gen Camaro SS LS LT General Discussions | 4 | 07-21-2008 03:33 PM |
