#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > I4 Turbo LTG Engine, Exhaust, and Bolt-Ons
Old 08-14-2017, 09:42 AM   #169
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Looking forward to a new 1/4 mile time from you!
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst
Michigan1LTRS is offline   Reply With Quote
Old 08-24-2017, 02:21 PM   #170
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Me too... Weather and tune permitting, I will be racing satuday...
Still chasing some knock retard in the tune, think it's got something to do with the trans TM...
Jason@JacFab is offline   Reply With Quote
Old 08-31-2017, 07:25 PM   #171
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Update for me please! Still only a CAI. Got a good start on this one.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 08-31-2017, 07:51 PM   #172
notoriousstad
Drives: none
how do you set up the 0-60 test?
mine only does 0-57 or 0-62?!! wtf?
NotoriouSS TAD
Betty - 17' Cam6 2.0T A8 2LT RS HMB
J5 - 96' Impala SS - 4700lb autocross machine
Langston 96' Caprice 9C1 Beater
Rosie - 67' El Co - race truck w/ plates
NoName - 73' Datsun 620 - LS7/TR6060/4.56/T2/NREMITT/9C1 guts
notoriousstad is offline   Reply With Quote
Old 09-01-2017, 04:07 AM   #173
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
If you go back a few pages, there is a walkthrough on how to fix it. I believe you have to set the MPH back to 0, then go back up the scale to 60.
ChicagoTommy is offline   Reply With Quote
Old 09-01-2017, 09:29 AM   #174
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
took me about 10mins of messing with everything to find that.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 09-01-2017, 02:14 PM   #175
notoriousstad
Drives: none
Thanks Tommy
NotoriouSS TAD
Old 09-01-2017, 02:15 PM   #176
notoriousstad
Drives: none
Now if I could find a hidden boost gauge on my 2LT RS non headsup Cam6
NotoriouSS TAD
Old 09-19-2017, 06:58 PM   #177
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
2016 A8 2.0t street tires factory 20inch rim
Mods Injen CAI evo7300, zzp catless DP, rpm bigger TB kit, magnaflow axl bk, tune.
Back seat removed. Gas tank @ 1/8
Traction control was on.
Best pass out of 2 passes
1/8 mile 8.709 @84mph
1/4 mile 13.39@ 102mph
Havent done a 0 to 60 since the tune yet
Beast-Y-Blue is offline   Reply With Quote
Old 09-20-2017, 04:59 AM   #178
ChicagoTommy
Who did your tune? You need to work on your launch, or you need a better tire. How are you launching? A 2.2 60' is awful! The racer's 'rule of thumb' is every tenth off the 60' usually equates to 2 tenths off the quarter ET. A 12 second pass isn't outside the realm of reason if you can get the 60' down to a 1.6-1.7! That would be cooking! Don't get me wrong, as that is a very solid start! Did you do any kind of data logging? MPH doesn't seem very high either.
Old 09-20-2017, 07:30 AM   #179
Beast-Y-Blue
Well this was my 5th pass ever as i never go to the drag strip, and only got 2 runs with a tune. Tires are not the best so was thinking with some sticky tires and traction control off i may be able to get closer to 12.9 to 13.1 range. Yes did some data logging and tuner was happy with the way car was running..
I was reffered to tuner by 6th gen gino , and is basically the same tune.
Also i tried to lower the psi in my tires but didnt get a chance to try different psi. I believe i had it at simewhere around 23 to 25 psi but i dont know if that is good or bad.
Old 09-20-2017, 09:17 PM   #180
Michigan1LTRS
Blessed ❤️
Dude, you got a 13.39 with that 60 foot? Lol That is amazing and you are in the 12's with a good launch. Great job!!!
Old 09-20-2017, 09:26 PM   #181
Wiehl
Wiehl's Avatar
Drives: 2018 1LT LTG
Who did your tune?
Wiehl is offline   Reply With Quote
Old 09-20-2017, 10:15 PM   #182
ChicagoTommy
Ok, so some kind of local tuner? It's a good pass for only your 5th pass on a drag strip! Definitely turn the traction control off, that's only hurting you.
What RPM are you launching at? If you have enough traction, you need to launch with some boost already built. It's easier for me since I'm typically drag racing my AWD Cadillac. I just stab the brakes and the throttle, and it revs to 3400ish, then let off the brake with no traction issue.
What are you using to data log? HPT?
In order to run your best pass, you need to know the variables like tire pressure. Personally, I don't run normal street tires under 25psi, it becomes a point of diminishing returns. You start introducing drag because radial street tires don't 'grow' like slicks do. Are you adding any air to your front tires? I usually bump those up to 55psi for the strip, that will help reduce rolling resistance as well. There are lots of little tricks like that, and that is what separates the people that run faster for their given mods, versus the rest of the people that never run well for the amount of mods they have! Try to keep a log of variable when you run, so you can monitor any changes. I try to keep track of tire pressures, launch rpm, boost, density altitude, temp, humidity, wind speed and direction.
