03-07-2011, 09:30 PM | #169 |
Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
I got a few photos from the track photographer at Homestead.
03-07-2011, 10:07 PM | #170 |
Drives: 2011 IBM Camaro 2SS/RS Join Date: Sep 2009
New video soon?
03-08-2011, 04:22 AM | #171 |
having FUN now 13.66@101
Beauwulf, those photos are AWESOME. Thanks for sharing.
03-08-2011, 07:17 AM | #172 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Best pics yet!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
03-09-2011, 06:54 PM | #173 | |
I've been in contact with EBC regarding the brake problem and I'm posting the E-mail traffic up to this point. I invited the correspondent, James Hallett to reply to this thread so, we'll see what they have to say...
Name=Terry Barker > Email Address:=beauwulf@bellsouth.net > country=United States > Comments:=I am using the Blue NDX compound on my 2010 Camaro and, at a > recent track day at Homestead Fl, had an issue with a "shudder" under > braking. > I'm using an inexpensive set of drilled slotted rotors that were used with > the OEM pads for several hundred miles before installing the blues. > > I installed the pads a couple of weeks before and used the bedding procedure > provided. I had about 600 miles on them when I went to the track. > > At the track, on my first hot lap, I got a progressively worse shudder in > the front brakes to the point that I had to pull off. When I got back to the > pits, I immediately used a digital temp gauge and had only 250F on the > rotors. I jacked the car and spun the wheels and had no extra drag or tight > spots on either side. So, we bleed the brakes and tried again with the same > result on the next session. > > Here's a link to the video of my runs > > > > Got any ideas? > ------ Forwarded Message > From: Terry Barker <beaugator@bellsouth.net> > Date: Tue, 1 Mar 2011 12:08:35 -0500 > To: Natalie Brown <studio@ebcbrakes.com> > Subject: Contact Us James Hallett - EBC Brakes wrote: > Hi Terry, > > Apologies for the late reply. > > I am copying our Research and Development lab on this, for any comments they > may have. > > We will get back to you soon. > > Kind Regards > > James > > With Kind Regards > James Hallett > Vice President > On behalf of EBC Brakes USA Inc. Hi James, Thanks for the response. I believe I have discovered the problem now. Here's a link to my "build" thread on Camaro5.com that explains what I found. http://www.camaro5.com/forums/showpo...&postcount=168 If you look at the photo in this post, you can see an area in the center of the pad that appears to be very porous (pre installation). This was one of the areas that was "impacted" with, what appeared to be, dust from the OE Brembo pads. It looked very much like sandpaper that is "loaded up". The area was tightly packed and had a shinny surface. In the photo, you can also see a few small areas of "blistering" raised on the surface of the friction material as well. I am assuming the residue that collected in the pads was in the cooling holes on the rotors. I believe the cooling ducts I have installed may have blown the dust out of the holes from the inside as I finally got the car up to speed. My duct layout is also featured in the thread on a previous post. BTW, I did do a "cursory" cleaning of the rotors before I initially installed these pads as a matter of course. I believe the porosity in the friction material is caused by an inconsistent mixture of particulates in the bonding medium. When the scorching is applied (without pressure on the surface) it allowed the media to boil off leaving voids in the surface. I would recommend a finishing process to restore the surface post "scorching" or, devise a way to keep the surface under pressure (contacted) while applying the scorching to the pads. I would invite you to comment on this thread with any thoughts you might have. This thread has had over 8000 views and, a large portion of those are following this discussion. If you read the thread a bit from the post link above, you can see the car and some of the comments on this particular problem. Any information you can add will be of great benefit to the membership! It would also serve as an introduction for you to our forum..... Thanks for your time... Terry > > > > > > >
03-09-2011, 07:54 PM | #174 |
Awesome photos of the car bud, she looks right at home out there! Curious to read the response from EBC and their thoughts about the pad issue. When's your next track day planned for?
Camp Steeda in may at Sebring would be awesome! Erik |
03-09-2011, 08:03 PM | #175 |
Sebring sounds doable in May... if I get the brakes worked out! Still have to test them....
03-18-2011, 11:43 PM | #176 |
Track > 1/4 Mile
Hey Beauwulf, I'm going to still your thunder for a little bit. Hope you don't mind!
Just got these put on yesterday. The front tires are the Hankook's that Beawulf is running (255/35) and the rear tires are the stock P Zero's (for now). Big thanks for Beauwulf, he pointed me in the right direction to get everything put together. These wheels are absolutely amazing!
03-20-2011, 04:13 AM | #177 |
i give you props not all of us can afford an ss im only 21 and i bought 2011 camaro lt rs and im finding myself putting alot of money in it
03-20-2011, 06:23 AM | #178 |
Drives: Victory Red 2011 Chevy Camaro 2LTRS Join Date: Mar 2011
I would have opted for an ss, but I didn't want the garbage monthly payment. Much props to you. My goal now is to own you on the track...me and my little V6 are going to have to take large strides, but twin turbos, tunes, intakes, and a little love from above might get me there...lol! Regardless...love to all my G5 Camaro brothers and sisters, you all rock!
03-20-2011, 07:36 AM | #179 | |
03-20-2011, 08:22 AM | #180 |
I think you just earned a new nickname...
"Willy Coyote" Beep Beep
03-20-2011, 11:35 AM | #181 |
Here's a link to my Sebring post. The race is on ABC TV right now!
http://www.camaro5.com/forums/showth...60#post2986060
03-20-2011, 02:56 PM | #182 |
Drives: CGM 2LT/RS M6 Join Date: Jul 2009
Beauwulf and Baylor those are great looking wheels. What brand are they?
Similar Threads | ||||
Must post picture of a Chevy to win. | "prima"Donna | Off-topic Discussions | 74976 | 09-13-2013 11:33 PM |
My mail-person dropped something in my box today | usa1camaro1969 | 5th Gen Camaro SS LS LT General Discussions | 4 | 06-12-2010 11:45 PM |
Look what I found today. | Crider | Cosmetics and Lighting Modification Discussions | 5 | 10-25-2009 09:32 AM |
Found and bought a CGM 2010 SS today... | Nine Ball | Camaro Photos | Spyshots | Video | Media Gallery | 96 | 06-04-2009 08:57 AM |
Found this in the paper today. 10,000 camaros ordered | Th3Nigh7Stalk3r | 5th Gen Camaro SS LS LT General Discussions | 31 | 01-05-2009 09:07 AM |
