10-04-2016, 01:28 PM | #183 |
Drives: '12 Hennessey Vert & '17 50th Vert Join Date: Jul 2012
Great point extra year on warranty is a win from my point of view :-)
Shoot straight, shoot often and share what you learn...My tactics instructor use to say "it doesn't matter what you carry, but you can never have enough ammo!!"
2012 Hennessey HPE600 Camaro Convertible Black, Inferno Orange Synergy stripes 2017 50th Anniversary Camaro SS Convertible |
10-04-2016, 02:22 PM | #184 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Also, pay with AMEX or CC that offers extended free warranty service
10-04-2016, 04:26 PM | #185 |
Drives: 2012 Grand Sport Convertible Vette Join Date: May 2011
10-04-2016, 10:45 PM | #186 |
I have not heard back from PAC on my issue. I'm hoping they address this and not decide to ignore it. From your comments I'm assuming these amplifiers can be purchased elsewhere?
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
10-05-2016, 12:40 AM | #187 |
Drives: 2013 Join Date: Dec 2013
Hallo,
my cmx chime module has arrived. Now i will install it under the center speaker in the dash board. Then all works fine. My TPMS now is working. With Scosche it was failing. The hazard button is not a good construction, but it works. Here my link to a few Pictures: https://photos.google.com/share/AF1Q...tDakEzcndwS1JB .
Chevrolet Camaro - V8 - MT - 2013 - European Version - Inferno Orange/ Inferno orange - ACC Sidemarker ghosted - Dash Kit PAC RPK5-GM4101 with DNX8170DABS - Amp KAC-8406 - Sub Pioneer TS-WX110A - Rear- and Front-Camera - ACC Mail Slot Scanner RGB - Pedders Sportsryder - painted parts in engine compartment - black powder coated original rims - H & R wheel plates 20mm front and rear axle - 1 LE steering wheel - MGW Short shifter replacement - aluminum door Pins - ACS T4 Splitter - us-mirrors - ZL1 side rockers - High Wing Spoiler
10-05-2016, 06:50 AM | #188 | |
Drives: 2015 2LS Join Date: Mar 2016
Antennae amplifiers can be purchased at many places. I just looked around until I found something I liked. from memory, I had to order but got it off Amazon using Amazon Prime and had it quick.
10-05-2016, 08:28 PM | #189 | |
Drives: '11 SW 2SS/RS LS3 Vert Join Date: Jul 2013
10-05-2016, 09:52 PM | #190 |
review
10-06-2016, 11:42 AM | #191 |
Drives: 2014 Camaro 2SS/RS Crystal Red Tint Join Date: Oct 2014
anyone know if you can just reuse the faceplate that's on my 2014 as it already has the wide opening for the mylink and that way would not have to swap over the knobs
Mods: V Max TB/ American Thunder Catback/ Granatelli Wires/ CAI/Catch Can,Stainless Power Headers/JRE Tune
10-06-2016, 11:52 AM | #192 |
I did some searching and found one with the correct Fark connector to make the connection to the factory antenna wire. Right now work has me out of town so Ive contacted Phastek to handle it for me as PAC is not responding. If that brings no resolution then I will order a replacement. Their not expensive but my mindset is that everything should work from the start. I'm sure it's just a fluke and not their fault.
10-06-2016, 01:03 PM | #193 |
Drives: 2013 2SS/RS L99 Join Date: Apr 2013
No, the screen on the Mylink faceplate is not part of the actual Mylink headunit, so you can't just pull it out and throw a different HU in. The link above provided by opossum has a bunch of pictures of what the Mylink Faceplate looks like when its off, and what the back of it looks like when you have to take it apart to remove the knobs.
10-06-2016, 01:36 PM | #194 | |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
Thanks..
10-06-2016, 01:54 PM | #195 | |
Drives: ZL1 convertible 2013 Silver Ice Join Date: Aug 2014
I did the same in my car, with a metra kit, and I have lost all car generated sounds: chime, back up parking sensor and so on. The reason seems to be coming from the mylink unit swap, as it gets these information from the BCM I guess. Does this new kit retain these sounds in your case? And if so, how does it work? THANK YOU |
10-06-2016, 08:31 PM | #196 | |
