Old 03-07-2010, 05:17 PM   #211
Fabrice
Drives: 98 camaro
thanks for the info.
Fabrice is offline   Reply With Quote
Old 04-23-2010, 12:34 PM   #212
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Green
Racing
Experimental
Engine
Narrative
Times change and so will racing. An All-Star group has been assembled by Robert Fisher and Circle Track magazine to build and track a 2010 Camaro using renewable fuels. It goes well beyond fuels and to the heart of what racing is all about -- cars on the track that are like the cars we drive on the street. If all goes well, they will put on track a car that captures the essence of NASCAR back in the Day with superior technology and superior performance that runs clean while using renewable fuels. Pedders will supply the suspension for Project G.R.E.E.N.
164086 Camaro Sports Ryder Supercar 52mm with Remote Canister
CAMAROSOLUTIONC 27mm F & 32mm R bars & 4 links
EP1167HD Zeta HD Differential Mounts
EP1201HD Camaro HD Rear Sub Frame Repl
EP2112 Zeta Steering Rack/Pinion Mnt
EP6577 Camaro Front Radius Rod Bush
EP7264 Zeta Rear Lower Control Arm In
EP7322 Camaro Rear Upper Control Arm
EP7323 Zeta Rear Trailing ArmToe Link
PDUSACAM2800 Camaro Complete Brake Hose Kit
PDUSACAMFULL Camaro Full Alignment Kit
You'll be able to follow this project in print or online is Circle Track magazine.
Dyno Test #1
Old 05-07-2011, 08:20 PM   #213
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
Originally Posted by mkaresh View Post
Thanks for posting this. No time to read them at the moment, but I assume everyone is raving about the car.
Key things I want to know: how big does it feel, and how communicative is the steering?
Update: after reading some of the reviews, the consensus seems to be that it doesn't feel quite as heavy as it is, but that the steering could be more communicative. The latter is a big deal to me, personally, but then very few current cars are satisfying in this respect.
Otherwise, the reviews have been glowing.
Keep the fronts inflated to spec and you won't have problems. Nothing worse than a set of low fronts. I always had a low front right tire on my F-150 due to a slow leak. After filling with air there was always a noticable difference. What's 'POWER, VARIABLE RATIO STEERING'?
I have an LT with RS and that's what I got for steering. See ya on the road!
Troy Lawson
lawman007 is offline   Reply With Quote
Old 07-29-2011, 01:59 PM   #214
JusticePete
You can clean up the steering feel with a good alignment. Have them bring the car to ZERO toe. That will help a great deal.
This is not the thread for vendors to sell parts, but swapping out the rubber OE radius bush snubbers / inserts and replacing them with a harder urethane insert makes a big difference in steering feel. The OE rubber hydraulically damped bush stays in place. It is just the snubber that is replaced. Simple to install and a far more direct feel in the steering. The alignment and snubbers can be done at your Chevy Dealer. The parts are GMPP licensed and of course they have an alignment machine. Add it to your new car negotiation.
Done deal IF you will throw in the GMPP EP6579 snubbers with an alignment
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
Car and Driver drives V6 Camaro! Xanthos 5th Gen Camaro SS LS LT General Discussions 63 08-26-2008 09:21 PM
News on Camaro coming on the 22nd CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 07-10-2008 09:02 PM
