#225 | |
![]() No matter how much is in your can it is a 100% improvement over stock. |
#226 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
Better in the can than in the intake
#227 |
#228 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: SS 1LE Join Date: Nov 2012
Any word when the new batch will be ready to ship?
#229 |
#230 |
no problem, thanks
#231 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
After seeing how much oil was not where it was supposed to be in my engine today, I just ordered and Elite catch can from you! Just hope thats really my problem and its not a bad ring!
2010 Camaro SS LS3 - No Modz
#232 |
#233 |
Hey chase, got your can last week in my thread post.
http://www.camaro5.com/forums/showthread.php?t=329892 I wonder my car came from dealership at about 8800 Or so miles.. bone stock ... so should i worry about the intake oil ingestion? I put my can around 9300 Miles or so. The Apex one. How much gunk do you think is in there can i just leave it alone and not worry about taking the car apart . Or is it absolutely necessary to clear it out and start fresh with a oil can.
#234 | |
#235 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Chase,
Can I seafoam the intake with the catchcan installed? I'm assuming no, but I wanted to check before I attempted this weekend...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
#236 |
No reason you can't.
#237 | |
For those of you following Project G5R, the Moreno's have chosen to go with the Apex Motorsports Catch Can. As with everything else in their build, the install was customized. Check out the latest update below.
#238 |
Here is another serious build featuring a Vortech supercharged LSA that is being protected by the Apex Motorsports catch can. It was built by Jordan Innovations and is being ran in the Red Line Time Attack Series driven by Conrad Grunewald. It started as a run of the mill 1994 Mazda RX7 Touring.
![]() And then all hell broke loose. ![]() ![]() ![]() ![]() ![]() ![]() All clean and buttoned up with Apex Catch Can in place. ![]() ![]() Conrad with the car at Streets of Willow a few weeks ago. |
Tags |
apex catch can, apex motorsports, catch can, elite engineering catch can, rx catch can |
