#225 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#226 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
yes, much better... upgraded or aftermarket would also be acceptable... but new works.... I will sleep better tonight!
#227 | |
#228 | ||
Track > 1/4 Mile
![]() Quote:
#229 | |
Track > 1/4 Mile
#230 | |
www.928m.com/parts/boostlimitervalve.php McMaster also sells a similar valve for about $10 but you will have to install multiple valves since they don't sell valves with an opening as large as 928's valve. Once the OD tune gets worked out, you can just dail up the boost like a turbo system!
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
#231 | |
Track > 1/4 Mile
#232 |
I believe this will be going into my build.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
#233 |
Track > 1/4 Mile
I've been doing some digging on this type of set up as a boost regulator. Ultimately it seems like it works pretty well, you just need to make sure you have it installed before the MAF sensor. So I'm thinking it wouldn't even be able to go on the MAF tube, probably the tube directly below the MAF tube.
The one main down side of doing this for my situation is the super charger will be working to make the same amount of boost (9-10 psi in my case) however it is counter intuitive to make your engine and super charger work harder to make more boost only to bleed it off and waste it. The plus side about doing this method over simply switching out a pulley is that you build boost faster, and you can regulate the boost levels like a turbo. Here's some pretty good info over on the Corvette forums: http://forums.corvetteforum.com/c4-f...st-levels.html
#234 |
Track > 1/4 Mile
***UPDATE***
WELL, guess I'm not supposed to have this FI set up. My MAF went out AGAIN. Luckily this happened a quarter mile from where I live. I am nearly certain it has nothing to do with the super charger itself, since I am not on the stock pulley and making half the boost I used to. I'm pretty sure it is the Rx Chiller I have. When my MAF went out the first time on my way back from Florida I pulled the MAF out and it had a fair amount of condensation on it, which didn't surprise me since I was in a humid climate AND the chiller was cooling the air to 59-62 degrees. Well, same thing happened, I pulled my MAF sensor out and sure enough it was covered in condensation. This is linked to my AC, so if I want to use my AC in my car the chiller HAS to be on. So sucks, because in my area it still in the high 90's to 100 degrees and will be hot for a couple more months. I have no idea what I'm going to do as I can't be shelling out $75+ a month for a new MAF, and to make matters worse no dealership in the greater Houston area stocks these so they have to order it from their warehouse that isn't open on the weekends. Which means I am probably going to miss part of a day of work ![]()
#235 |
Track > 1/4 Mile
MORE Bad news!
Well the shop that did the pulley swap (Advanced Racing Dynamics in Katy Texas) must not have tightened the bolt that connects the tensioner to the super charger unit, because on my way home from work I heard the loud clank of the bolt coming out and doing God knows what inside the engine bay. So now the belt is just slipping because there is NO tension on the super charger belt. It's always something with my car! UGH. Anyone with the Rx System know the bolt size that goes from the tensioner to the super charger unit?? *EDIT* Tracy just PM'ed me that it is SAE 3/8" coarse thread. But if anyone knows the length that would be great. I think it is around 2" or so.
#236 | |
Don't Sleep on My V6
Sent from my Galaxy Tab 2 using Tapatalk 2
#237 |
Track > 1/4 Mile
Exactly what I was thinking.
#238 | |
![]() ![]() Drives: 2011 1LT "Chakita". 04 Yota Join Date: Jun 2011
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083 |
