#239 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Thanks for the update Todd and Steve. Look forward to hearing what we should do. Best luck. Todd, 2015 with no mechanical woes ... I'm rooting for you!
-CRT Sent from my iPad using Tapatalk
#240 | ||||||
Hey Doug, yes and i will continue doing the same, i currently still have Dot 3 in the clutch but Dot 4 is going in when they put her all back together. Quote:
#241 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Dang Crush!
keeping positive is the way to go. congrats on the PB, BTW!!!
#242 |
![]() ![]() ![]() Drives: 2022 SS 1LE Join Date: Jul 2013
Thanks guys, hoping if I do this clutch right that the car will hold up for a while. I've got the DSS 1,000 axles and a fully forged engine. Please let this clutch be the last weak link, LOL.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
#243 |
Guys, after discussing at length with various suppliers that build race cars, I decided to go with a full race clutch. I'm at 600 HP and 580 Ft-Lbs at the flywheel, and I will do a full season of NASA competition next year.
First, thanks to Jacob at SNL / Monster Clutch, I think their solutions are the best choice for 95% of the forum members and at an excellent price. But my car is a dedicated track car and has been plagued with breakdowns, so I'm going overkill and have chosen a different solution. I went with a Quarter Master Optimum-SR 10.4" Two-Disc Clutch, Flywheel & Release Bearing. This is a heavy duty billet unit rated at 1,400 HP and 1,000 Ft-Lbs. In addition, they have a kit to beef up the slave cylinder including a billet steel bearing housing that we all know is a weak link. This is the same set up as the Grand Am Continental Tire Sports Car Challenge Series Camaros run and has been shown to reliably withstand the stresses of long track sessions: http://www.quartermasterusa.com/qm/o...kit-14170html/ I'm also going with the seperate clutch and brake reservoirs, remote clutch bleeder and a braided clutch line. Seperate reservoirs = safety. If the clutch pukes, you don't lose your brakes (almost happened to me, scary to see a puddle of fluid under your car after tracking at 125 MPH) This had better fix it!!! Really tired of all the breakdowns and expense. Here's the good news- the shop that's fixing it is located at Buttonwillow Raceway, so I will be able to test the crap out of it immediately after the work.
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 Last edited by Orange Crush 1LE; 12-10-2014 at 12:31 PM. |
#244 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
For the rest of us, just wondering if indeed that stock slave cylinder is the problem...(poor quality, bad design, etc.)....Just wondering if it's even possible to avoid failure at some point, or is it inevitable?....I mean, if once the clutch starts to stick, are we doomed?....Has the cylinder gone bad from lack of bleeding? Would it be worthwhile to add a braided line and bleeder to the existing set-up or just ride it out until/if it all fails like yours did and then upgrade everything?.... ....If you or your mechanics could possibly pin-point what goes bad first...fluid, lack of bleeding, heat stress on cylinder fluid, etc....and if there is any reasonable preventive maintenance that could be done in the meantime, or if a complete up-grade and replacement is the best way to go...It would sure help a lot of us to know what to expect or which direction to go in the meantime... Maybe that's asking too much of the proverbial crystal ball, but we sure aren't getting any good direction from the GM dealerships...lol... Thanks, and good luck. Tom. |
#245 | |
I know I had old nasty black fluid around the time the trouble began, so that may have contributed. My engine builder told me that merely removing and replacing the engine is hard on the crappy stock slave cylinder, so that may be part of the root cause. No question the slave cylinder is horrible, everyone in the clutch business I talked to knew of the problem with the plastic bearing housing. But we'll learn more is he digs in. I already know one thing- if anyone has the car apart to replace the master, may as well replace the clutch to. The Monster clutches are reasonable in price, may as well upgrade clutch and slave as soon as you have the dreaded symptoms.
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 Last edited by Orange Crush 1LE; 12-10-2014 at 01:04 PM. |
#246 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 C7 Z51 Join Date: May 2012
That Quarter Master clutch looks very good! If the following statement is correct, it will also feel great to use!
http://www.quartermasterusa.com/qm/o...kit-14170html/ Quote:
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
#247 | |
Most of us perhaps can go the MonsterClutch route....The QuarterMaster looks like at least a grand or so more... ...All good...I think I'll start here first when the time comes: http://monsterclutches.com/gen-5-cam...ace-multi-disc |
#248 | |
Drives: 2014 SS Join Date: Jan 2011
#249 | |
#250 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Did I just read $2700 on that quarter master? Holy crap....
Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
#251 | |
#252 | ||
Gulp, yes, that's right. It was a hard pill to swallow. Quote:
And thanks again, you guys were very helpful. Like I said, best solution for most.
