02-06-2014, 12:10 PM | #2591 | |
knows 2 facts about ducks
I bet you could get that intake manifold to fit. I'll bring the hammer |
02-06-2014, 12:39 PM | #2592 | |
Drives: G5.R Join Date: Sep 2010
Inspiration, LOL
Quote from Jamie: " I can make a RS3-LR intake with a single 102mm TB. The plenums openings need to be 105mm apart, and it looks like I can get them this close with about a 6.5" long runner. This is only 1.5" shorter than a stock GM LS7 intake manifold. If you go ahead with it, I will try to push it closer to a 6.75 or 7" runner (but cant guarantee it)" Our response was to make the runners as long as possible as we can always mod the hood. We will be running a NW billet TB. |
02-06-2014, 12:49 PM | #2593 | |
02-06-2014, 06:11 PM | #2594 |
Drives: cars Join Date: May 2011
Love your cooler setups. With removal of all the plastic guiding air towards the radiator you may want to look at that once you mock up the front bumper to keep air forced through the radiator and keep it sealed properly. Not sure if you already have something in mind for that.
Did the vararam intake go tits up so you're going another route? Delivery timeline still too much up in the air? Or do you just want something else billet to polish with your dremel? Would like to see something economical come out by this winter but I know what you're looking at now aint what I'd call economical so I'd have to pass. |
02-06-2014, 07:02 PM | #2595 | |
This thread isn't good for our wallets! LOL
Plus the OZMO is more in keeping with our thyme. We will probably do a different cam more track friendly, TD rockers and Mast head and Daily dry-sump. Should be done till we go to a larger displacement. |
02-06-2014, 07:24 PM | #2596 |
Done? Ha.
I haven't found a dry sump that wouldn't require a/c removal. Might need to convert to a vette front drive or something if I want to go that route. I'll wait til the motor implodes and then figure it out. |
02-06-2014, 08:15 PM | #2597 | |
G5.R still has "list To do" (see below) to be closer to done:
02-06-2014, 08:21 PM | #2598 |
Drives: 2010 Camaro SS/RS CGM Join Date: Dec 2011
Don't do a 2014 hood unless it's a zl1 hood with the center showing the carbon fiber. It would match your theme too!
02-07-2014, 12:42 AM | #2599 | |
Krusher, here is kinda what we were thinking. Raising the cowl an additional 2" with the vents in carbon like the Z/28. But I think we will be able to get away with the stock cowl hood line. We are making a raise hood anyways for the guys running blowers who want to keep their rain dish. Thanks to Brunogadget for the photoshop! Here's the final design. The runners are 6.8". The intake will sit approx 3.5 higher than stock. OK, need your guys input. Should we run the rails on the inside were you wont see them or on the outside? I am thinking outside... Notice the new design on the intake is now a one piece billet housing for the TB. Josh's ( See pic below) was a two piece design. Last edited by Moreno1; 02-07-2014 at 01:50 AM. |
02-07-2014, 08:11 AM | #2600 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
That really is the first manifold with the rails on the outside that ive liked just as much as the ones with them hidden on the inside.
Tough call, both look great, and with them on the outside it fits the mechanical theme you are going for, but inside fits the clean theme better haha. I think the angle you posted for the outside-rail one is probably the most flattering for it, any other angle the one without rails would win. I vote rails on the insdie. |
02-07-2014, 08:45 AM | #2601 | |
The outside looks cool but as clean as everything else is under the hood on your car, I would go inside and show off as much of the manifold as possible. |
02-07-2014, 10:13 AM | #2602 |
I would agree with Chase keep it hidden and supa supa clean.
And with the hood, I just don't like how the new camaros made the hood cowl wider, but then put a dinky little louver in (Relative to the ZL1 hood). The ZL1 hood has a bigger louver for more cooling and it follows the body lines better. I do really love your car though and I know it will look awesome no mater what. |
02-07-2014, 11:34 AM | #2603 | |
[COTW 5/12/14]
It is extremely dinky |
02-08-2014, 01:33 AM | #2604 | |||
We had a really productive day on the harness. Should have about 5 more minutes and it will be DONE! LOL In the pile are all are all the wires we removed. Here all the wires we removed! The wire cutter gives some perspective. This doesn't include all the sensors, modules, etc... all told, I would say we removed around 15 lbs. Last edited by Moreno1; 02-08-2014 at 01:47 AM. |
Similar Threads | ||||
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
