Old 09-15-2010, 08:15 AM   #15
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Matt.....this is what you are looking for! The kit includes the fog light housing from the non RS model to run the 5202 HID kit. If you want to match your factory HIDs, make sure to select the 4300K bulbs.
http://www.camaro5.com/forums/showthread.php?t=95867
http://www.bfxenon.com/Camaro_RS_Fog...-camarorsf.htm
Old 09-15-2010, 12:12 PM   #16
Matt'sSS
From 2 door to 5 door
Matt'sSS's Avatar
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum
Hey, an HID reply!
I've looked at their kits and it just didn't do it for me. For this kit in particular, IMHO if you're paying this much for a vehicle specific kit #1 you shouldn't need to cut up the factory wiring, and #2 I'd want projector (not reflector) housings actually designed for HID's with a cut-off as to not cause glare issues for other drivers.
That's why I was specifically asking about the P13W HID bulbs, since there's not (to my knowledge) a "proper" HID setup readily available specific to our cars, I was hoping the guy promising the P13W bulbs had come & maybe I just missed it. Apparently not
Thank you though, much appreciated!
Matt'sSS is offline   Reply With Quote
Old 09-15-2010, 03:32 PM   #17
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Originally Posted by Matt'sSS View Post
Hey, an HID reply!
The only part of the wiring you have to cut is the plug for the DRLs and add the new one to fit new plug on the HID kit. Its very easy.
As for the projector here you go.
http://www.automotivelightstore.com/CamaroFogKit.aspx
Old 09-15-2010, 05:06 PM   #18
sting808
Drives: 2010 SS RS
Camaro fog and drl are the same housing. Only difference is the bulb socket and the fogs has an adjustable angle screw. Both reflector will produce glare since they are not designed for HIDs.
The AAC projector kit requires the back of the fog/drl "cup" in the bumper needs to be cut. Once done, you can never go back without replacing the bumper.
OEM HID housing are designed to cut glare with some type of shield during low beam driving. There is no perfect, cheap, and easy HID solution that addresses glare, heat, and retains stock design.
At least not yet. I picked up the fogs and stock harness for $150. Trying spencerHiDs 25 watt HIDs with a manual switch override. If I still have too much glare, I'll need to settle for the brightest LED 5202 available.
Everything is subjective. Good luck with the options. RS P13W options are few.
sting808 is offline   Reply With Quote
Old 07-24-2011, 04:45 PM   #19
XtremeHeartbeat
"The MistreSS"
XtremeHeartbeat's Avatar
Drives: 2011 Black Camaro 2SS RS 6M
I know this thread is nearly a year old, but has anyone found a P13 HID bulb yet?
XtremeHeartbeat is offline   Reply With Quote
Old 07-24-2011, 04:48 PM   #20
The Stig
knows 2 facts about ducks
The Stig's Avatar
yes, I have P13W bulbs in my DRLs.
http://www.automotivelightstore.com/P13.aspx
Click to view my build thread
Old 07-24-2011, 04:51 PM   #21
XtremeHeartbeat
"The MistreSS"
Thank you, but like the OP, I was looking for HID's.
Old 07-24-2011, 04:54 PM   #22
The Stig
The Stig's Avatar
HID P13W bulbs don't exist. AAC does sell an HID kit that replaces your fog lights however. http://www.automotivelightstore.com/CamaroFogKit.aspx
Old 07-24-2011, 05:40 PM   #23
XtremeHeartbeat
"The MistreSS"
That's what I figured... I think ill just get new lenses and convert to 5202s... thanx for the info.
Old 07-24-2011, 09:41 PM   #24
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Here you go: http://cgi.ebay.com/ebaymotors/15w-H...#ht_1713wt_948
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 07-24-2011, 09:42 PM   #25
Camarowguy
Camarowguy's Avatar
They are 15 watt too!
Old 07-25-2011, 12:54 AM   #26
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Originally Posted by Camarowguy View Post
What's a camara?
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 08-08-2011, 09:47 PM   #27
wadew2lt
U.S. Army Veteran
wadew2lt's Avatar
Drives: 2LT/RS SGM M6 Polished 20's
PWM??
wadew2lt is offline   Reply With Quote
Old 08-08-2011, 10:11 PM   #28
jennnchuck
jennnchuck's Avatar
Drives: 2010 yellow 2lt/rs
i got mine from ijdmtoy.com. the price was great and they have held up great so far
jennnchuck is offline   Reply With Quote
BF Xenon H13 8000K HID Bulbs Deepsky Exterior Parts & Accessories 2 08-24-2010 08:38 PM
HID DRLs or LED DRLs? CrunkGJ1230 Cosmetics and Lighting Modification Discussions 0 04-25-2010 12:06 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 01:07 AM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 12:19 PM
