01-05-2011, 02:27 PM | #15 | |
Ted.
www.jannettyracing.com
01-05-2011, 02:30 PM | #16 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
If your forcing air through the heads then its not as critical on the intake as touching up the exhaust side of things and the cam wants to be biased for FI as well again for the exhaust side of things.... Then you have HP goals as well and better heads do make better power but again with FI and forcing the air through them its not a critical an area but aftermarket heads usually have thicker decks and 6 bolt options as well so its really how much boost and hp are you looking to make.
If your building a 416 then you can run what ever you want for boost as long as you deal with the compression smartly. Its not a contest to see who can run the most compression and boost at the same time... |
01-05-2011, 02:37 PM | #17 |
Yeah...my bad, for some reason I reverted back to the unforged boost limits. I still didn't realize after forging that boost is recommended to be run that high.
01-05-2011, 02:45 PM | #18 | |
My goal is about 600 rwhp with 416 ci and stock heads (modified as recommended) and a ZR-1 cam. I have the e-force and 1 7/8" LT headers already and am making alittle over 500 rwhp now. Most of the build threads I've read for FI 416 ci are using a 9.5:1 cr so that's along the lines of where I thought I'd want to be...I don't know if my goals are too modest or too much for that setup. I'd also be doing the ADM dual fuel pumps, JRE e-force fuel rails and upgraded injectors to at least 65lbs.
01-05-2011, 04:03 PM | #19 |
BAMF SS
600 should be cake work for any shop, if you already have a lower compression/forged bottom end to work off of.
def. should NOT have to step up to aftermarket heads or a 6 bolt block/head.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-06-2011, 01:07 AM | #20 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-06-2011, 01:27 PM | #21 |
Makes sense...I'm just trying to find the right balance of power and engine strength....thanks!
01-03-2012, 09:54 AM | #22 |
Drives: 2007 Corvette Z06 Join Date: Oct 2011
Just so everyone here knows, You absolutely cannot use ls7 heads on an ls3 unless the bore exceeds 4.100. The intake valve will hit!!! There is only 22-32 thousanths clearance between the intake valve and piston. hopefully no one has made this mistake.
01-03-2012, 11:08 AM | #23 |
Drives: 2011 SSm6 Join Date: Oct 2011
I have been told by a few good sources that LS7 heads will clear a 4.065 bore, not ideal but will clear. I assume you are talking about .022-.032 valve to piston clearance? You talk about it needing a 4.100 bore, but yet say the intake valve will hit the piston? Can you clear that up? Interested to hear from someone whos been there.
01-03-2012, 11:59 AM | #24 |
Drives: Camaro Join Date: Apr 2009
We offer a cnc ported 390cfm LS7 head that clears the stock bores because we relocated the valves. You cannot put a stock LS7 head on a LS3 engine properly. The good news is our aftermarket casting LS7 small bore heads fit properly & gives you lots of features over a stock gm head.
01-03-2012, 01:57 PM | #25 |
Does the LS7 head require a different header than the LS3?! (a la the LSX454?!)
not to hijack but I asked this in another thread and never got a response. I have Kooks Stepped headers (which prob would be too small for the 454 anyway) but I am just wondering if regular 2" headers will bolt right up or if you need custom made headers.. Thanks
2011 2SS/RS L99
2017 Chevy SS 1979 Z28 Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495 MY BUILD THREAD |
01-03-2012, 02:56 PM | #26 |
Jason, any dyno testing on the LS7 top end on an LS3?
01-03-2012, 04:04 PM | #27 |
Drives: 2010 2SS/RS Red Jewel L99 Join Date: Jun 2011
As far as I know,LSX454 will work with your LS3 headers.You'll need to change the intake to a LS7 or a aftermarket intake because the intake ports are not the same as the LS3.
01-03-2012, 07:28 PM | #28 |
Drives: 2005 C6 Join Date: Apr 2011
The LS7 is a great head but with the right porting LS3 heads can perform very well on the LS3 or L99. Check out the link below.
http://www.camaro5.com/forums/showthread.php?t=187554 |
Similar Threads | ||||
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 04:35 PM |
5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 10:06 AM |
LS3 Specs, and Descriptions | Mr. Wyndham | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 11-06-2007 01:04 PM |
