#15 |
![]() Drives: 2010 2ss 6 speed Join Date: Apr 2011
gears
With the mods that i am doing this winter the gear change was one that i wanted to make the right call .
Thanks for the feedback |
#16 | |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
I agree. Also, anyone wanting we have Diffs in stock complete. ![]() |
#17 |
1337 AH64D driver
Drives: 2010 Camaro 2SS/RS L99 Join Date: Sep 2010
I'm going to end up doing the same thing.
I dont want to go to aggressive so just the jump up to 3.45 will be enough for me
Cam/Heads by ARD, Tune by G-Force, Transmission/Gears by Circle D
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Padre swapped his stock gears for LS3, 3:45s. He also documented his track times.
He said the gears made daily driving better (especially once he got his cam), but he didn't see much of any gain at the track. 12.06 @ 114.0 mph - stock gears 12.02 @ 113.9 mph - 3:45 gears Both times corrected for DA for comparison. So don't expect much improvement at the track with them. |
#19 | |
Mods: "Cam Only"
#20 | |
CamaroFans.com
#21 |
Drives: 2010 Camaro Join Date: Feb 2010
When we experimented with gears at the track the 3.45's allowed the car to be in 4th longer, at higher rpms, resulting in higher trap speeds and lower ET's.
#22 |
So it basically seems that if you are looking to improve et's then 3.25 to 3.45 are a waste of $. So I guess I am back to looking at LPE 3.70 gears. I have considered 3.91 but I think they might be to much gear for my auto especially with the insane 1st gear. I would definitely need slicks to get it to hook. I doubt my nt05r could hook. Also with the 3.91 I'm afraid it would shift right before the traps. Are my assumptions about the 3.91's correct?
Mods: "Cam Only"
#23 | |
More than likely the 3.91 will be to much gear. What's the rwhp of the car? |
#24 | |
And I will be going FI in the future.
Mods: "Cam Only"
#25 |
![]() ![]() Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
FI= 3.45 in most cases it seems.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
#26 |
I'd put the 3.45's and be done with it. You could get away with a 3.91 now but once you go FI forget about that. All you'll do is blow the tires off and cross in 5th.
#27 | |
Mods: "Cam Only"
#28 |
Drives: 2010 2SS/RS Red Jewel L99 Join Date: Jun 2011
If you would have 3.91's and your trap speed would be 120mph. The rpm's would be 6500.
